start with 10 degrees initial timing, and 13 degrees mechanical advance in the distributor(26 at the crank), and get the mechanical advance all in by 3000 rpm. that seems to be about what the small block ford windsor wants timing wise. you can then bump the initial timing up to 4 degrees more if you need it. mild windsors seem to like a total of 36-38 degrees.
