Timing & Suspension Woes...need some input.
  • Thread starter Thread starter Mike86Stang
  • Start date Start date Mar 29, 2004
Mike86Stang
Advanced Member
Apr 11, 2000
10,296
Red Lion, PA
Mar 29, 2004
  • Mar 29, 2004
t with the timing, I tried backing my timing down to 10* b/c i'm only running 87 octane with my 19's & the car ran like crap. It had no power bucked & popped in the exhuast started to over heat & the headers started glowing orange. So i put the timing back where I had it at 18* & it runs alot better, no over heating no glowing headers all on 87 octane. This isn't making any sense to me. The car should be detonating it's butt off, but won't even run at base timing. I checked the dampner for walking (I marked it when it was new) & it hasn't budged. So the timing marks are as accurate today as they were about 2 years ago when I replaced it. Should I just accept the fact the engine needs alot of timing??? It seems to me something must be wrong for it to need all that timing & not run on base time. WTF
Another thing is I've been getting more than my normal share of wheel hop out of the rear axle. It also feels like it "wiggles" under the car when under WOT. If I ease from a stop I eigther get a pop/clunk sound out of the right rear or I get wheel hop. I've had the quad shocks off the car for quite sometime now & has not made a diffrence up until now. The quads have been off for going on about 2 years. I looked at the bushings & they look fine beside squeeking or groaning over the occasional bump. I looked at the torque boxes & I don't see any tares or seperation from the frame.
I don't know what else to look for.
Any ideas fellas/ladies???
TIA
MIKE
shawn13
70
Dwight IL
Mar 29, 2004
  • Mar 29, 2004
sounds like your rear bushing are shot i just redid my whole car with prothane bushings love them to my timmings set at 20 and i can run 87 gas no prob in my 89 gt
Mike86Stang
Advanced Member
Apr 11, 2000
10,296
Red Lion, PA
Mar 29, 2004
  • Mar 29, 2004
Thanks for the input, anyone else have some feedback?
9
93 331 GT
60
Jackson, NJ
Mar 6, 2006
  • Mar 6, 2006
Timing is Ok. I would check with Steeda to get the most out of your cam. some cams require more advance to work well, that may be why your car runs bad at stock timing. As for your suspension, the stock setup has all rubber bushings, and your lower contol arms are mounted to the sheet metal of the body. If you are going to keep the car where it is at as far as power you "might" be okay with changing the bushings. If you are planning to add more power (torque), you may want to invest in a good set of lower control arms and torque box reinforcements along with the polyurethane bushings.
Trust me. It started with popping, then the next thing I know I had three one inch tears in one of my torque boxes, and that was with my bolt-ons for my stock motor (no longer using), and no power adder. I also do a lot of drag racing (street and track).
Suspension Quad shocks
  • keel
  • May 20, 2026
Fox 5.0 Mustang Tech Sep 2, 2026
AeroCoupe
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Long Time Coming
  • 85gtCOBRA
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 18, 2025
2Blue2
