  • 1994 - 1995 Specific Tech
Timing/Temp????
  • Thread starter Thread starter titaniumsc03
  • Start date Start date Jul 24, 2005
T
titaniumsc03
42
ohio
Jul 24, 2005
  • Jul 24, 2005
Timing/Temp pulling my hair out please help????
OK heres the deal, I just but my 95 5.0 about a month ago. i just put a full exhaust on it this weekend and decided that it felt a little sluggish so i decided to check the timing, I pulled the spout out, fired it up and checked it, it was 5*ATDC, right there i was confused. These cars come stock at 10* BTDC right? any way i advanced it to 12* and took it for a test ride, it ran good except it made alittle noise in 3rd, dont know whether it was pinging or an exhaust leak but i am running 89 in it. and the temp also jumped to the L in normal, while before i messed with the timing it was staying in between the N and the O. BTW i have a 180 * highflow tstat in it.
Could the timing been set that low to hide a cooling problem? or maybe a detonation problem? what would you guys think the culprit is, thanks for your help
Russell
BTW i put the timing down to 8* still heats up??????????????????????
HISSIN50
34
129
Jul 24, 2005
  • Jul 24, 2005
The balancer might have slipped, so the timing had been correct, but the point of reference was now off. But you should have really seen some issues were that the case. You could use a dial indicator to get it to TDC and see where the balancer is. Do ya think that is possible?
What are your ambient temps? FWIW, I have to run 91 octane at 8* advance when it is over 100*F.
Good luck.
T
titaniumsc03
42
ohio
Jul 25, 2005
  • Jul 25, 2005
the car was a dog and didnt really like to rev quick thats why i checked the timing, i figured out that the detonation i heard was actually the pasenger side header leaking, so it wasnt pinging when i had it at 14, just heating up. and at 14 it ran awesome, major difference. thanks
Russell
T
titaniumsc03
42
ohio
Jul 25, 2005
  • Jul 25, 2005
ok its 95* here today and it heated up to the a, and pinged, so maybe the balancer is off, what should the timing read with the spout plugged in??
SQUEEZE&STROKE
SOUTHERN CA
Jul 25, 2005
  • Jul 25, 2005
With the spout in it will be all over the place...the computer controls it...you're right with the spout out though-10*btdc. Carefull with the timing that high, detonation isnt always heard...but with the temps rising that quickly and that high it still might be detonating
T
titaniumsc03
42
ohio
Jul 25, 2005
  • Jul 25, 2005
i have it at 8* right now with 87 octane, is that too high, or is that where its supposed to be and im chasing another problem? my passenger side header is leaking a little too Thanks
Russell
T
titaniumsc03
42
ohio
Jul 25, 2005
  • Jul 25, 2005
ok, while having my dad double check the timing i realized the fan wasnt kicking on, duh, even though the two times i checked the timing it was working
Russell
T
titaniumsc03
42
ohio
Jul 25, 2005
  • Jul 25, 2005
ok got the fan wired to high at all times, sits at the n with my 180 tstat, but it still pings in the midrange, tomarrow im going to try to run 93 instead of 89
HISSIN50
34
129
Jul 25, 2005
  • Jul 25, 2005
The GT's run a bit too much computer mandated timing advance - Grady can provide tons of info on that.
I live in the desert and run 91 octane at 8* base timing (set with the SPOUT out).
some things that can help are: cleaning the MAF, IAT, ECT, running some top end cleaner, etc.
Good luck.
RIO5.0
6,892
N.H.
Jul 25, 2005
#10
  • Jul 25, 2005
  • #10
The scurge of the SN95...pinging....Search and read up on that one....It can be tough to cure...
State of tune is good???, plugs/wires, etc???
You may wanna try a topend cleaning such as Seafoam?? Carbon build-up can be a contributor to pinging...
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Tunerstudio help / services
  • Kabuki_notch
  • Apr 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum May 2, 2026
Mustang5L5
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
