Timing
  • Thread starter Thread starter Scorcher2005
  • Start date Start date Sep 15, 2004
Scorcher2005
883
South Carolina
Sep 15, 2004
  • Sep 15, 2004
I just ordered a new cap, rotor, plugs, and wires and want to get the most out of them ass possible. By the single wire connector, what do you mean? I see there is a plug in the front right under the cap but that has like 5 or so wires in it. And when you point your timing light at the crank pulley, where do you aim it at? It doesnt look like much access to it. What i can see though is a little bracket with a eyelet in it - am i supposed to aim it there or at the very top of the pullry or what? And whats the reason of pulling out the module/plug thing? Thanks.
HISSIN50
34
129
Sep 16, 2004
  • Sep 16, 2004
the spout removes the timing advance from the puter - you should do it. if you trace the TFI harness upstream about 6 inches, you will find it. pull the chip (spout) out of the end of it.
i like to use one of those silver markers to mark the timing marks on the balancer. some use white out or chalk. i dont like using the advance mechanism on timing lights, so i mark 10* and whatever i want (12 or 14*, etc). then loosen the dizzy hold down - i find using a 1/4" ratchet and a swivel and some extensions works best. move the dizzy where you want it and lock it down. recheck the timing (tightening the hold down can move the timing slightly). install the spout.
if while driving at any time you hear pinging, back the timing down ASAP.
good luck.
Scorcher2005
883
South Carolina
Sep 17, 2004
  • Sep 17, 2004
ok, i found the little chip thing, but im still not sure where the light is supposed to be pointing at on the crank. all i can see of the crank pulley from above is a little bracket with an eyelet and then about 2 inches on the right it has a little triangle pointer. Is that where im supposed to aim the light at?
OL' WHITEY
273
Weddington, NC
Sep 17, 2004
  • Sep 17, 2004
Yes. That's where you read it. I tell you what I'd do. I'd get under the car with a flashlight and a bottle of white-out (car not running) and take a look at the marks on the crank pulley. BTW you may have to bump the starter a couple of times to get all the marks down at the bottom. Mark a line at 0. Mark a dot at 10. Mark two dots at 15. Then when you get back up top with the timing light, you can see the marks much better and you won't have to try to read the numbers as they whiz by at 700 rpm.
Turbo6
15
  • Sep 17, 2004
Don't forget to replace the spout connector before you take off and lose it
Scorcher2005
883
South Carolina
Sep 17, 2004
  • Sep 17, 2004
thanks guys, now i only lack the motivation...MAYBE it will get done tomarrow...
00 Red SS
270
Grain Valley, MO
Sep 17, 2004
  • Sep 17, 2004
The flat edge at the top of the pointer is what you use to line up with the mark on your balancer.
A
AJBlackGT
  • Sep 18, 2004
I actually find it easier to change timing with the car at about 2k rpm, that way the light is not flashing, but its almost stuck on and you can read the timing marks way easier.
HISSIN50
34
129
Sep 18, 2004
  • Sep 18, 2004
might i ask, do you have a third hand? im a retard and have enough trouble keeping the timing light wires from getting sucked into the serpentine belt and holding the gun (not jambing it into a pulley) and moving the dizzy.
im just messing with you - that sounds like a good idea (though i have not had trouble with setting it at idle) - just thought i would bring up that it is one more thing to occupy one's self with while timing the car (if it is his first time timing a car). an assistant holding the pedal/linkage is a different story.
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
96 GT 4.6 w/ dirty spark plug well
  • Mustang Momma
  • Apr 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 9, 2026
LILCBRA
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
