  • 1994 - 1995 Specific Tech
Timing
  • Thread starter Thread starter Synned
  • Start date Start date Apr 20, 2005
Synned
took tubgirl on a date and got banned
Mar 31, 2005
991
Philly
Apr 20, 2005
  • Apr 20, 2005
Hey, can someone explain to me how timing and degrees work? What is it for I always see it. I'm such a newb it's not even funny.
Thanks
OL' WHITEY
273
Weddington, NC
Apr 20, 2005
  • Apr 20, 2005
Geez, I don't even know where to start with this one. In a nutshell, if you advance or retard your engine's timing, you are changing the exact moment the spark is being made in the combustion chamber. If you advance it, the spark happens sooner, and your piston has not reached top dead center in the combustion chamber. If it's at 0 degrees, spark happens at top dead center. If it's retarded, spark occurs when the piston's on it's way back down. Our cars are set at 10 degrees advanced from the factory. You can advance timing more and get more hp. The tradeoff is the need to run a higher grade of fuel. A 5.0 N/A likes around 15 degrees on 93 octane for max power. How's that for an explanation?
5.0snake
95
South Eastern PA
Apr 20, 2005
  • Apr 20, 2005
I just did my timing yesturday and set it at 13*...it was around like 5* hahahaha
91LX_5L
1,943
British Columbia
Apr 21, 2005
  • Apr 21, 2005
Notice a big power diffrence?
black945.0
76
  • Apr 21, 2005
you dont have to run higher fuel mine was about 13 advanced and i ran 97 no knocks or pings i wouldnt run higher gas unless i absolutley had to save me some cash if u have carbon build up on ur pistons then u might get a knock due to the allready increased combustion area then u would run higher octane
OL' WHITEY
273
Weddington, NC
Apr 22, 2005
  • Apr 22, 2005
Uh...Black...I think you meant you run 87, not 97. Here in NC, 93 is sold as super, 89 as mid, 87 as regular. As you pointed out, you may not have to run super after a timing bump, but most people do. The best thing to do is bump the timing and see if it pings under a hard load (WOT). If no, you're okay. If it does, you'll need a higher grade of fuel.
Synned
Mar 31, 2005
991
Philly
Apr 22, 2005
  • Apr 22, 2005
And you need a Tweecer to bump the timing? Correct?
T
tderrick
312
Apr 22, 2005
  • Apr 22, 2005
No, take spout out. use a timing light to spot the mark you made on the balancer at given degree mark..
Loosen distro, and turn for adjustment....
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Ignition Question
  • WantAn88GT
  • Sep 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
WantAn88GT
L
5.4 4v base ignition timing table help.
  • leoleo
  • Aug 16, 2026
Digital Self-tuning Forum Aug 17, 2026
MustangBetts
M
P
I need definitive heater valve and AC expansion valve answers
  • PurAU
  • Sep 26, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 1, 2026
GypsyR
G
