timing
  • Thread starter Thread starter MustangGlx
  • Start date Start date Jul 8, 2005
MustangGlx
147
Connecticut
Jul 8, 2005
  • Jul 8, 2005
Im timing my mustang, i was wondering with my mods if it would be bennificial to advance or retard the timing? set up as follows
302 around 11:1 compression
hi-po 289 heads ported and polished
edelbrock rpm air gap intake manifold
comp cams magnum cam, 528 lift 230 durration at .050 inch timing
holley 650 double pumper
long tube heddman torque step headers
msd 6a ignition and blaster II coil
thanks
302 coupe
1,952
Macon, Ga.
Jul 8, 2005
  • Jul 8, 2005
With your compression, its likely that you won't be able to advance your timing very much without some detonation. Shoot for as much intial as you can without excessive pinging, then get your total advance to 34 or 36 degrees, all in by 2800 or so rpm. Pretty much standard practice for a mild build with factory head castings.
12sec67
1,301
San Diego, Ca
Jul 8, 2005
  • Jul 8, 2005
you could also use the adjustment in your vacuum advance that could help you set your total timming.
thehueypilot
1,084
Medina,Tennessee
Jul 8, 2005
  • Jul 8, 2005
I agree, but you will need to keep your intial timing a low as possible (maybe 10 degrees) with that high of compression ratio otherwise you will blow a head gasket or worse if detonation occurs.
D
First post 289 rebuild question!
  • Ddyer2868
  • Nov 24, 2025
Classic Mustang Specific Tech Dec 5, 2025
rednotch
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
R
351w stroked to 408 CARB
  • Ric4eyedFox
  • Mar 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2025
General karthief
C
347 stroker power estimate? Expected 1/4 mile run?
  • clayton seiders
  • Nov 29, 2023
  • The Welcome Wagon
The Welcome Wagon Nov 29, 2023
clayton seiders
C
