timing
  • Thread starter Thread starter 87Mustang351
  • Start date Start date Apr 19, 2007
87Mustang351
220
Canada, Nova scotia, Cape Breton
Apr 19, 2007
  • Apr 19, 2007
hey guys i was wondering what i should set my timing to, to get a little more out of my car, mods are in my sig
thanks
todd
4G-KDMP
935
CA
Apr 19, 2007
  • Apr 19, 2007
thanks
todd
start at 12-13 degrees and then work your way up to where you start to hear it ping, then back it down a degree.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 20, 2007
  • Apr 20, 2007
I have read a lot of 351w build ups. Mostly i see 18 degrees initial with 20 degrees of mechanical advance. so 38 degrees total. Thats what I run and my engine loves it. Because i have a 8.2 to 1 compression I can actually run low grade and not ping. I like to run High grade however due to my nitrous. I would do as the other post say though. bump it from 14 degrees up 1 degree at a time.
87Mustang351
220
Apr 20, 2007
  • Apr 20, 2007
ok man thanks alot shes only on 12 degrees right now...any problems with them being ahrd to start when they get warm
87Mustang351
220
Apr 20, 2007
  • Apr 20, 2007
got the timing pretty close today shes still off a little, at around 210-2400 RPM its sputtering and then the same at around 2700 inbetween all that its good. so i think my timing need to be adjsuted a bit better...im a newb tho
also my advancced timing on my distribtor is not workin we had to block the line to get the car to run right, i dont know whats goin on with that
87Mustang351
220
Apr 21, 2007
  • Apr 21, 2007
to teh top
EMW150
2,020
Roaring Spring,PA
Apr 21, 2007
  • Apr 21, 2007
Don't set it for base timing, set it for total advance and let the base timing fall wherever. I locked my advance out on my dizzy and I set it at 3000 rpms and then check it at 7k. Mine loses 2 degrees past 5k so I set it at 38 at 3,000. 36 is what my car runs best at. The initial doesn't matter much unless you run into starting trouble. If you do you can run a start/retard or try to curve it. You want max advance early (by about 2500) if you want to run a timing curve. This of course is for Non-EFI cars only.
87Mustang351
220
Apr 21, 2007
  • Apr 21, 2007
soon as i put my advanced vacume line on the car spits and sputetrs and wont even idle i dont know what to do, i have the line blocked for now and its running alright but has the sputters downlow
EMW150
2,020
Roaring Spring,PA
Apr 21, 2007
  • Apr 21, 2007
I hate vacuum advance. I'd leave it unhooked and let it work off the centrifugal advance. Set it at about 36 degrees at 5000 rpms and see where the initial falls when you let it back to idle. It'd be nice for you to pick up an MSD Dizzy. They're easily adjustable whatever curve you want and no vacuum advance, all centrifugal
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 21, 2007
#10
  • Apr 21, 2007
  • #10
I don't have a vacuum advance. My car is a little hard to start in cold weather but in the summer its no problem
G
Electrical Getting good ground in 1991 Fox Vert for amps - getting popping noise when I turn on the lights?
  • gvanginkel403
  • Apr 11, 2026
Fox 5.0 Mustang Tech Jul 21, 2026
gvanginkel403
G
Engine Standard or hi flow water pump?
  • AnthonyA1234
  • Sep 28, 2026
Fox 5.0 Mustang Tech Oct 9, 2026
2000xp8
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
K
Drivetrain '87 5.0 Installing New Ring Gear and Pinion - Pattern Questions
  • karhoot
  • Apr 23, 2026
Fox 5.0 Mustang Tech May 9, 2026
Mindseye007
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
