timing?
  • Thread starter Thread starter p0prcksandc0ke
  • Start date Start date Oct 13, 2007
p0prcksandc0ke
111
sacramento,ca
Oct 13, 2007
  • Oct 13, 2007
i just bought a timing light, the instructions are not very help full, can some one give me a stept by step instructions, an i dont know wut im doing how the timing light work wut to point it at and what i need to know everything, thanks
Skymarshal
572
Dallas
Oct 13, 2007
  • Oct 13, 2007
The light will have a red and a black clamp that you'll attach to the positive and negative posts of the battery, and an inductive pickup clamp that you clip around your #1 spark plug wire (the right-front wire). The clamp is marked as to which way should face the plug, so make sure you have it on there right. Make sure all the wires are away from any moving parts, start the engine, and turn the light on. Point the flashing strobe light at the timing pointer just above the harmonic balance on the front of the engine (the main pulley on the lower front of the engine). The pointer is a little toward the left side of the engine, so that's where you want to shine the light. Read your timing setting on the markings on the side of the harmonic balance. They might be hard to see, so it helps to wipe some white paint into the markings with the engine off.
p0prcksandc0ke
111
sacramento,ca
Oct 13, 2007
  • Oct 13, 2007
thanks that helps alot but i dont have an harmonic balancer, and there are no markings on the pully
D
D.Hearne
11,730
south louisiana
Oct 14, 2007
  • Oct 14, 2007
You do have a harmonic balancer, it's the 1" thick metal behind the crank pulley. The timing marks are usually coated with paint or gunk, you have to claen all that off to see them. I use white chalk rubbed on them to see them with the light.
R
Electrical 1987 Map Light
  • Riley Barth
  • May 30, 2026
Fox 5.0 Mustang Tech Jul 6, 2026
Riley Barth
R
P
Rear disk brake caliper parking brake adjustment
  • parrotguy
  • Oct 23, 2025
1974 - 1978 Mustang II Talk & Tech Oct 24, 2025
2Blue2
L
5.4 4v base ignition timing table help.
  • leoleo
  • Aug 16, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 17, 2026
MustangBetts
M
T
Progress Thread 2002 Mustang 3.8L CV
  • TheIncompetentMechanic
  • May 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 1, 2026
T
F
Leak from tail shaft after 2 new seals
  • Fox123
  • Aug 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 9, 2026
JD1964
