twogts4us said:When I was ready to install the new plugs, I stuck the old plug on the end of a foot long piece of rubber fuel line, then dabbed some anti seize on the threads and ran it down into the plug port as far as I could until I felt resistance. Then I removed it, cleaned the threads, dabbed a bit more anti seize on it, and repeated. I did this until I could run it all the way down without resistance. Then I dabbed the new plugs and installed. You dont want to screw up these aluminum heads!
Other than this tip, I essentially followed the instructions on the Bullitt Registry as someone noted above. Easy stuff, but take your time.
I've used the fuel line hose trick several times. Works great. 3/8" fuel line if I remember correctly.
