Tips for removing 5.0 engine
  • Thread starter Thread starter frankthetank886
  • Start date Start date Jan 4, 2007
F
frankthetank886
  • Jan 4, 2007
Hi, I am getting ready to take out my 302 engine and I was wondering if anyone could give me some tips. Thanks!
SQUEEZE&STROKE
SOUTHERN CA
Jan 4, 2007
  • Jan 4, 2007
Dont break the wire connectors or vaccuum lines, they become a PITA to track down later.
Make sure all the grounds/wire connections are disconnected
Have all the right tools first...good set of sockets, fuel line disconnectors, etc
Take some digital pictures before, during and after so you have a "manual" to put it back together.
Oh, and good luck! The only way to learn is to do...Dive in!
drakesdad
961
Oregon OHIO
Jan 4, 2007
  • Jan 4, 2007
I agree 100 percent on the pics.........they come in handy........if it's your first time or so place nuts and bolts into labeled baggies................it will help from getting confused with a bunch of bolts...............you will be fine.........good luck...
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jan 4, 2007
  • Jan 4, 2007
PB blaster is your friend
you dont need to disconnect a/c lines or fuel lines (can just swing them off to the side out of the way
drain all fluids
put all your bolts in seperate baggies and label them!!!!
pics help
remove the hood! its easy to do and will make the job a lot easier
ProKiller
3,064
15
78
PA
Jan 5, 2007
  • Jan 5, 2007
drain all fluids
pics help
you don't have to drain the steering fluid or brake fluid, just the oil and coolant
Black95GTS
1,644
Marlborough, MA
Jan 5, 2007
  • Jan 5, 2007
When we did my cousins for his 347... we got a bunch of different colored zip ties from walmart. There was 10 or so different colors. When we disconnected a vacuum line for example, we put a green zip tie on one end and another green zip tie to where it attached.
So during reassembly, we never had to scratch our heads. Green to green, red to red, etc etc. We also did the bolts in zip lock bag trick. One last thing, I highly recommend one of these: http://www.sears.com/sr/javasr/prod...otive+Specialty+Tools&vertical=TOOL&ihtoken=1
Adam
1slow95
1,797
ohio
Jan 5, 2007
  • Jan 5, 2007
http://forums.stangnet.com/showthread.php?t=572882
blkcobra50
209
  • Jan 5, 2007
I know many have said nuts and bolts should be placed in labeled bags, which is a great idea. When I did mine I put the bolts and nuts in the location where they came from. For instance, thread the 4 bolts that hold the hood to its hinge back into the hood after it is off the car. This will keep the parts in original locations and help not to have to look for parts in a lot of bags. It was helpful for me. Good Luck with the project.
L
Leezure
104
  • Jan 5, 2007
I found that labeling both ends of every wire and vacuum line connection with masking tape and a black marker helped me get everything back together.
Believe it or not there will be a part left over that you haven't marked and you'll have no idea where it goes. Just put that in your spare parts box.
F
frankthetank886
#10
  • Jan 5, 2007
  • #10
Thanks for all the help! I will be taking out the engine tomorrow so if anyone has any last minute tips that werent already listed please let me know. Thanks!
carbed87
215
#11
  • Jan 7, 2007
  • #11
going to pull my motor around spring, and that zip ty tip sounds like it's worth it weight in gold! thanks
Zero Signal
2,633
Tucson, AZ
Jan 8, 2007
#12
  • Jan 8, 2007
  • #12
If you are going to keep the tranny on when you pull it, drain the tranny fluid then put a bag around the tailshaft becuase it's going to drip and make a mess anyway.
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
Snapped off ECT when trying to remove.
  • 88VertFox
  • Aug 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 15, 2025
88VertFox
P
Vacuum
  • ProTechAutoServices
  • Aug 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
