Tire Height Calculator
the link was bad, but you can figure tire height by adding sidewall to rim size...for example 235/50/R15's would be 235*.5=117.5mm (the .5 is because the middle number-50-is the percentage of the first number, or section width, and .5 is 50%). There are 25.4mm in an inch so 117.5/25.4=4.63 on each side, so 4.63*2=9.26+15(rim size)=24.26 inch tide height...cool?
it is not difficult (aspect ratio is the height and is a percentage of the tire width).
do note that different tires can vary quite a bit. the lower the profile, the less sidewall bulge there is, and this affects the physical measurements. try hitting a tire shop with a ruler - i bet you find that tires of the same numeric size measure out differently.
Yount knows a ton about this stuff (his bro is in the tire business). listen to him (i bet he posts in the morning). good luck.
