tire's too big!! need help.
  • Thread starter Thread starter tony91723
  • Start date Start date Dec 27, 2004
T
tony91723
71
  • Dec 27, 2004
alrite guys I've got a problem. I have a set of 28x11.5x15 MT ET street tires on a set of 2 piece draglite rims. I was wondering if I could fit some smaller tires on them that are not soo wide. I think its too much tire for a pretty much stock set up. I have 3.73 gears in the rear and a stock t-5 what do you guys recommend going with? I was thinking something like 26x10.5x15 and would any of you want to trade these tires? I have no use for them for a smaller set of slicks.
giddyup306
3,041
Dec 28, 2004
  • Dec 28, 2004
Try heating and beating the inner fenderwell. That should help.
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Dec 28, 2004
  • Dec 28, 2004
It could be an issue of rims as well.
What size/backspacing are the rims?
T
tony91723
71
  • Dec 28, 2004
I have no idea on the backspacing, I am going to have to measure it. I do know they are 15x9's atleast thats what I was told when I bought them. the tires are giving me a problem rubbing up on the quad shock I saw in another thread someone switching the position of the quad shock maybe that'll help with the clearance. and either way don't you guys think these tires are too big? 28x11.5x15? the only reason I have them is because they came with the deal on the rims....so I figures heck I might as welll run them and see how I do. you guys have any recommandations on a smaller tire?
rsw007
469
Lexington,SC
Dec 28, 2004
  • Dec 28, 2004
26x10 will be fine
T
tony91723
71
  • Dec 28, 2004
thats what I was thinking, I am going to try the quad shock trick and see if that helps me out any.
rsw007
469
Lexington,SC
Dec 28, 2004
  • Dec 28, 2004
actually a 26x8.5 et drag will work also
5.0guy
320
MI
Dec 28, 2004
  • Dec 28, 2004
my quicktimes rubbed, so I took a mini-sledge to the inner fender.
axeman
1,348
Elizabethtown, PA
Dec 28, 2004
  • Dec 28, 2004
28" tire is definatly too big. go with a 26x10.5 or 26x11.5 ET Streets, or maybe a 26x8.5 or 26x10 ET Drag. hoosier sizes should run about the same. any way you look at it, the 28" tires are hurting performance.
Mike86Stang
Advanced Member
Apr 11, 2000
10,296
Red Lion, PA
Dec 28, 2004
#10
  • Dec 28, 2004
  • #10
Ditto, 28's are killing your effective axle ratio.
Tires
  • 65er
  • Dec 18, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 9, 2026
Realmongo
O
Good all around perfornace-ish tires?
  • optionizerSS
  • Jan 25, 2026
2005 - 2014 S-197 Mustang -General/Talk- Jun 15, 2026
TPony
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
K
help find right tires
  • kagan21
  • Dec 8, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 10, 2024
FastDriver
Engine An engine building combo with stock Speed Density (SD) system
  • Mcmahst
  • Jan 14, 2025
Fox 5.0 Mustang Tech Jan 15, 2025
Mcmahst
