TKO 600 Questions
  • Thread starter Thread starter 90' LX 5.0
  • Start date Start date Aug 18, 2006
9
90' LX 5.0
59
  • Aug 18, 2006
Ok.. so if i want the best of both worlds... (acceleration and decent cruising capabilites) Would the TK0 600 with the .82 5th gear ratio be my best bet?
And going with the TK0 600 would give me the advantage of having the 26 spline setup which is superior to the 10 spline... (they do make a 26 spline tko500 though)
And another few questions cause im kind of uneducated when it comes to this stuff..
But will the Cast Iron Stock replacement flywheel work with the TK0 trannys' 26 spline setup?
And at summit they sell two centerforce clutch kits for the 5.0 (26 spline) one is 10.4 inches in diameter... the other is 11... which one is the correct one?
Thanks for the help guys.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 19, 2006
  • Aug 19, 2006
The .82 5th gear was designed for the road race crowd. The idea was that there is less RPM drop between 4th & 5th gear. For a street or drag race car, you will probably never get to 5th gear.
For best highway economy, choose a trans with .68 or .64 for 5th gear.
This chart is for a T5 and stock diameter tires, but it will give you some ideas on what the .6x 5th gear will be like.
See http://www.corral.net/tech/gearcalc.html for a calculator that you can input your own values into for more accurate results.
Stock flywheel will work with no mods.
Unless you have a wild engine combo (NO2 or pressurized induction) stick with a King Cobra pressure plate for a street/strip car. Do something different if it is a strip only car. A 10.5" Chevy clutch disk will mate with the TKO 600's 26 spline input shaft. See http://www.hanlonmotorsports.com/ or http://www.ddperformance.com for transmissions or clutches. You'll get the best advice on what fits & why from them.
9
90' LX 5.0
59
  • Aug 20, 2006
Thanks for all the information and help. Ive almost got everything together...
As far as the Starter Index Plate aka Block Plate aka Spacer Plate goes... will the one from ford made for the T5 work with the TK0 600?
Im getting the 600 with the .068 OD... and have everything else pretty much picked out and ready to order...
9
90' LX 5.0
59
  • Aug 26, 2006
So i just ordered everything that i need for the swap. What all do i need in terms of hardware? and where can i find it?
Like the starter plate to bell housing bolt
Transmission to bell housing bolts
Will the parts i ordered come with the stuff?
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Engine 302 production block selection
  • FastDriver
  • May 19, 2024
  • 2 3
8K
Fox 5.0 Mustang Tech Jul 1, 2025
FastDriver
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
SOLD 1991 LX hatch 5.0 (347/TKO) Elgin, Texas
  • LarsD
  • Sep 20, 2019
3K
Fox Body Mustangs For Sale (1979-93) Sep 20, 2019
LarsD
