I did some more research (lots of reading( and came across a post on the Corral by FordStrokers lining this out.
If you want to run a roller cam designed for a roller block in a non-roller block then you need link-bar lifters and you are done.
If you want to run standard roller lifters then you will need a reduced base circle cam, drill and tap the block for the spider to hold the dog bones. The holes that you will drill and tap are right over the #2 & #4 cam bearings so they will have to be removed and replaced to do this.
Hope that helps and I learned something in the process.
