Tko??
The same as it would normally take. There's no difference between the two that I'm aware of. Only the T5 from the Fox and SN had the input shaft length differences.
The usual. There's been lots of threads on it, so just look up TKO install. But in short, you need a fox bellhousing (or tremec), 26 spline clutch, 31 spline output shaft, some crossmember modifications, fox clutch fork....
