TO bearing
merc123
420
North GA
What issues can arise from the throw out bearing starting to wear?
Also, what guages should be gotten? I was thinking oil pressure and something else. What should be the something else :)
You will generally get a squeeling noise from a worn TB that becomes quiet when pressure is applied to the clutch pedal. As far as gauges go, I recommend oil pressure and water temp. You may even want to consider adding a low oil pressure light, like autometer's.
