To high flow cat or not to high flow cat?
Tarp
56
Austin Tx
well its getting close to inspection time and as you can see in my sig I have o/r x pipe and flows, well I have a set of high flow cats sitting in my closet and I am curious as to what yall think should I or no. I am looking for people who have experience with both
thanks ahead!
Depends on how strict your area is. If you have MIL eliminators, your car will pass the code test, but will fail visual, since you have no cats. My suggestion is to go to a place you trust that won't look under your car :D
I agree. If you take it to a place that does an OBD II scan, you will pass as long as you have MIL's or a custom chip to turn the rear o2 sensors off. If you go to a place that goes by visual inspection, then you wont pass unless if you have some sort of converter system. I have mac hi-flow cats on my setup but they were expensive. Nearly 300 dollars between the price of the cats and installation fees.
I have the Bassani catted Xpipe. PA does the sniffer test and with only 500 miles on the cats the car just barely passed emmissions (HydroCarbons: 75; limit:76) Good luck passing the sniffer test with aftermarket cats. I'm sure there are some aftermarket ones better than others but none come close to OEM. Bassani/Catco brand SUCKS!
