  • SN95 4.6L Mustang Tech
To the Tech Gods
  • Thread starter Thread starter TorqueMonster88
  • Start date Start date Feb 14, 2007
TorqueMonster88
46
  • Feb 14, 2007
I was wondering how do increase the rev limiter...what is needed....is it possible to have a 8 or 9 rev limiter....if this is a stupid question...sorry......hahahaha...just really curious
san~man
O-G
A little grass shack on a big lava rock
Feb 14, 2007
  • Feb 14, 2007
You have to increase it via the computer, but your stock motor won't rev anywhere near that high.
TorqueMonster88
46
  • Feb 14, 2007
What would it take........how costly is it
myponyrocks
I have more billet on the Stang than most women ha
Apr 18, 2004
1,219
Feb 14, 2007
  • Feb 14, 2007
a predator, sct, or any other handheld tuner... so 250-400 bucks depending if you go new or used... and I strongly suggest new as used stuff isn't covered under a warranty.
Superhereaux
chicks make me feel inadequate
538
South Texas
Feb 14, 2007
  • Feb 14, 2007
new tune to supply enough fuel and remove the 6250 rev limit
new stronger valve springs. that's all i can think of off the top of my head. i'm sure there's a few more but there's really no point
as far as revving to make power, we're talking major cash. new or p&p heads, lumpy cams, new intake setup, full exhaust, complete fuel upgrade, tune, lightweight flywheel and driveshaft, we can go on...
BurningRubber
1,865
24
58
Feb 14, 2007
  • Feb 14, 2007
I know someone that has a cammed/bolt on/nitrous GT, 100% stock internals and has revved it to 7200 rpm as set by a Diablosport tuner.
He did this a few times and the engine did not blow up.
san~man
O-G
Feb 14, 2007
  • Feb 14, 2007
Well, if you hit that rpm for a sustained amount of time, something is sure to break (on a stock motor). Then again, the thread starter is asking about 8 to 9k, which is a lot more.
BurningRubber
1,865
24
58
Feb 15, 2007
  • Feb 15, 2007
No doubt at all on that. I told him he was pretty crazy for revving a stock NA 2v that high, let alone with alot of bolt ons, cams, and spray. But... hes done it, still runs like a beast. He has backed the limiter down since then.
Dusstbuster
I love meat more than anything! I just have a spec
May 31, 2004
1,462
33
64
Moorhead, Minnesota
Feb 15, 2007
  • Feb 15, 2007
It would take the following, minimum (more than I'll list probably), to even concieve of a non honda-VTEC engine to rev to 8+RPM's without blowing.
Making things like the driveshaft and such lighter so the engine doesn't have so much stress on it when it's spinning that fast...
A totally built top end and probably a fairly well built bottom end, valvesprings, valvejobs, probably notching the pistons for more peace of mind to avoid PTV contact, opening up your coolant ports to allow the engine to cool off after revving that high to prevent some internal-welding from happening.
And a tuning device (dyno, handheld, reflash??)
It wouldn't be worth it by any means, and most definitely not economical.
katshot
17
Dover, DE.
Feb 15, 2007
#10
  • Feb 15, 2007
  • #10
I'd like to know WHY you want to rev it that high? You're WELL past your max power, so what would be the point of revving so high?
blackfang
1,290
Richmond, Va
Feb 15, 2007
#11
  • Feb 15, 2007
  • #11
That was going to be my question, but you got it.
Stang|ess
seeking cyber partner(s)
Oct 18, 2003
941
Hawaii
Feb 15, 2007
#12
  • Feb 15, 2007
  • #12
I think you can go about this 3 ways:
1. Rev that high and blow **** up (no upgrades other than a tuner to remove the rev limiter).
2. Rev that high but be way past your peak power. In other words useless. (upgrade valve springs, oil pump, tuner, bottom end)
3. Rev that high and make power. (Above + cams, head work, and some stuff I'm probably forgetting)
are you trying to immitate f1 cars? the reason why their v8, v10, v12 whatever they have can rev so high is because they have an extremely small displacement in relation to the amount of cylinders.
make yourself a 2.0 v8, with some 4.56 gears, and have fun .
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Feb 15, 2007
#13
  • Feb 15, 2007
  • #13
The modular is not the right platform for you if you want a high rever.. the stroke is too long and bore too small. high rev motors tend to have shorter strokes and less extreme rod angles. you would be better off with a SBF
TorqueMonster88
46
#14
  • Feb 16, 2007
  • #14
oohhh.....hahahaha...i asked this question mainly because the sound of a high revving v8...is like heaven to me...just was wondering if it was possible with a mod engine....soo...i gues this would be a project for the ppl with more money huh?...
alright well thanks for the info....u guys really now ur *****..hahaha
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Feb 16, 2007
#15
  • Feb 16, 2007
  • #15
There are a lot of high revving modulars out there, but they have done work to the valvetrain. There is nothing inherantly characteristic about a modular motor that doesn't allow it to rev high, it's just like any other motor, you really need to upgrade the valvetrain to make it more stable and durable.
But like mentioned above, with the stock heads/cams, you stop making good power after 6k RPM's usually.
O
injectors keeping up?
  • optionizerSS
  • Apr 4, 2025
2005 - 2014 S-197 Mustang -General/Talk- Apr 4, 2025
optionizerSS
O
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
G
Help! 93 Mustang 2.3L A4LD dies at idle
  • goofyfoot53
  • Nov 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
goofyfoot53
G
W
Electrical 91 GT Alternator Replacement Question
  • willrh111
  • Oct 22, 2025
Fox 5.0 Mustang Tech Oct 23, 2025
nickyb
9
2012 Boss 302 help
  • 94blackvertgt
  • Aug 21, 2025
2005 - 2014 S-197 Mustang -General/Talk- Aug 21, 2025
