  • SN95 4.6L Mustang Tech
Toasted starter?
  • Thread starter Thread starter Malevolyn
  • Start date Start date Jan 4, 2006
Malevolyn
18
Lakeland, FL
Jan 4, 2006
  • Jan 4, 2006
Last night, I started up my car. It started normally and idled for about a second before stalling. I tried to started again, then the starter made a single turn then I heard a loud "KLUNK." I tried again with the same result. Could my starter be dead?
D
Dragstr05
643
Stafford VA
Jan 4, 2006
  • Jan 4, 2006
I guess it could be starter related. I'm very curious though if it was the starter, why would the engine stall AFTER its already running? Once you release the key from the start position, the drive gear on the starter returns to its normal position and doesnt contact anything until you start it again.
R
Roger_4.6_96
1,209
Reno,NV
Jan 4, 2006
  • Jan 4, 2006
Tap it lightly with a hammer and see if it frees it up. I Think its time for a new one.
Malevolyn
18
Lakeland, FL
Jan 5, 2006
  • Jan 5, 2006
Yeah, I thought that was strange, too. I guess it could possibly be more than one problem.
I'll try that. Also it was kinda cold when it happened, but then again this is Florida so I doubt that was it. I've been too worried to try it again.
CManT1914
3,172
Killeen, Texas
Jan 5, 2006
  • Jan 5, 2006
Try jumping the two big terminals together on the starter, and see if it starts. If so, it's probably your solenoid that's gone bad. If not, try hitting it with a hammer, and starting it. Also, check to make sure all your grounds are good and tight.
Malevolyn
18
Lakeland, FL
Jan 5, 2006
  • Jan 5, 2006
I tried it again a few minutes ago and it's more or a really loud, really low pitched squeak than a klunking sound. I can get a sound clip if anyone wants it.
If anyone here as ever tried to reverse in a Saturn Ion with the parking brake on, it's kinda like that.
Update: Sound Clip
Malevolyn
18
Lakeland, FL
Jan 5, 2006
  • Jan 5, 2006
I talked to my dad about it and he said the flywheel might be on a bad tooth and the starter can't catch it. Does this sound about right?
(Sorry about the bump. I need to get this fixed so I can go out and find a job. )
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
M
2004 v8 convertible
  • Mikeycrownvicluver
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 15, 2026
Mikeycrownvicluver
M
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
