  • SN95 4.6L Mustang Tech
TOB?
  • Thread starter Thread starter JD2001GT
  • Start date Start date Jun 11, 2006
J
JD2001GT
10
  • Jun 11, 2006
I have to replace my TOB. It is chirping and Im really tired of it. I plan on putting the TKO in like next year but i wanted to fix this problem at the moment. Is any TOB going to work or should i get some kind of aftermarket one? I was going to get one from napa or something unless you guys think that Im going to have a problem with it
merc123
420
North GA
Jun 11, 2006
  • Jun 11, 2006
You could spray it with lithium grease I think and it should stop squeaking until you get the TKO.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Jun 11, 2006
  • Jun 11, 2006
all the TOB are awfull.. right now I have the one that came in my king cobra clutch kit in there it's good so far.
DTNODYA
831
  • Jun 11, 2006
Is there a special technique to this? I took the little plate off and shot white lithium onto the TOB but it started squeaking like a mofo again after like 10 mins.
bakos24
I find there is nothing better than a tasty wiener
87
134
NE, OH
Jun 11, 2006
  • Jun 11, 2006
I tried the same thing and stopped for like 5 mins.
J
JD2001GT
10
  • Jun 12, 2006
Anyone else have any ideas? I have been hearing that alot of people have problems with chirping and I just want to get one that is half way decent that I wont have problems with.
9
99svtdlb
40
Pittsburgh, PA
Jun 12, 2006
  • Jun 12, 2006
I have sprayed lithum grease in there before and it helped... my recommendation would be to get a Ford TO bearing. I wouldn't trust any other because they probably are all crap.
J
JD2001GT
10
  • Jun 12, 2006
Yeah I just found a motorsports one for 35 bucks. Ill probably go and pick it up tommorrow and grease the input shaft correctly this time. LOL
RandyStinchcomb
1,159
Randallstown, Md
Jun 13, 2006
  • Jun 13, 2006
well the Frpp one is nothing more then a re-boxxed stock Ford one, in which you paid @$10.00 more for it.
one thing about TOB is clutch itself, there are varrations in p/p and clutch thickness and run-out that can cause the TOB to make noise, so just dont think its the bearings fault. I had great luck wth RAM's TOB, think the part # is 501
J
JD2001GT
10
#10
  • Jun 13, 2006
  • #10
I had put the ram one in originally with the ram clutch i bought. I didnt originally grease anything at all so i think i may have damaged it when i put it in. I got that one because i didnt want to just get one from the autoparts store and it suck. I plan on replacing the transmission along with obviously everything else in the next year or two with either a T56 or a TKO 600, so I basically just wanted something to get by with.
D
Dragstr05
643
Stafford VA
Jun 13, 2006
#11
  • Jun 13, 2006
  • #11
When I bought my 00 GT used last june, my TOB started chirping after a couple weeks. It got worse, and I finally replaced the bearing. All was well for several thousand miles, then it started coming back lightly, and eventually it was back to the way it was. Funny thing is, sometimes I do hear it chirp, but its actually gotten better after it got worse, so I really dont know what the deal is.
I have also noticed that alot of people talk about greasing the bearings during install, but for the OEM bearing it specifically says in the factory service manual not to lubricate the bearing because they are already lubricated from the factory. When I pulled mine out of the bag, it certainly wasnt bone dry, but I dont know.
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
Rear Decklid Finish - Lost Gloss
  • 120rir
  • Oct 1, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 1, 2026
120rir
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
M
new member
  • markmoon
  • Jul 24, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 24, 2026
General karthief
