told i had a cracked ring ???
  • Thread starter Thread starter putnam88
  • Start date Start date Dec 13, 2006
putnam88
102
tavares
Dec 13, 2006
  • Dec 13, 2006
i have oil coming out my pcv could it be due to worn pistons, cracked or bent rings???
N
noslow1986
274
oswego Il
Dec 13, 2006
  • Dec 13, 2006
i have little oil in my too i wouldnt worried about it to much
rickd93_lx
162
  • Dec 13, 2006
change the valve
Black1987Stang
1,422
Jersey Shore
Dec 13, 2006
  • Dec 13, 2006
u do have that wire mesh under the pcv valve right???......to check for blowby supposedly u can just take off the oil cap with engine running and see if u feel positive pressure
gcwh02
515
pottstown, PA
Dec 13, 2006
  • Dec 13, 2006
before you get upset, check your compression.
putnam88
102
tavares
Dec 14, 2006
  • Dec 14, 2006
i have not check compression yet but i do have the screen in and i took off my pcv hose and smoke and oil was shooting outta it
F
FeTTstang
61
  • Dec 15, 2006
Yea that doesnt sound normal. Do a compression check.
304billet
315
  • Dec 15, 2006
change the valve. I had blowby on my 347 stroker from rings that did not seat properly. The blowby pushed the dipstick out of the holder by about 1/2".
I have never heard a cracked ring will make ur motor puke oil out the PCV valve.
putnam88
102
tavares
Dec 19, 2006
  • Dec 19, 2006
i have replaced the pcv and thats what i had read or the rings worn or thw cylinder and on the compression strok all the pressure will go to crank case and out pcv
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Nov 4, 2026
skidad
Engine Would you replace these OEM motor mounts?
  • 91GTstroked
  • Sep 21, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
Potomus Pete
D
Transceiver Ring
  • dtarang
  • Aug 22, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 22, 2026
dtarang
D
