- Feb 11, 2007
- 763
- 3
- 18
Here is my setup:
351W
9.8:1 compression
retrofit hydraulic roller cam.
Specs identical on intake and exhaust: .530 lift, 230 dur @ .050, 110 centerline. That is all I know for the cam
trick flow twisted wedge heads (not the CNC ported ones) i think 170cc
Edelbrock performer RPM air gap manifold with 750 cfm carb
C4 with 2300 stall converter
8" with 2.73s (still looking to upgrade that
I originally thought I had an intake gasket leak, because it would pull very little vacuum. I swapped the gasket and it seems to pull 14 inches of vacuum at idle, but in gear it pulls around 5-7 inches! That is with an idle speed around 650-700 rpm. The distributor is properly adjusted to 36 degrees total, but the manifold vacuum reading was taken without the vacuum advance connected, which is right now connected to ported vacuum source (I was also doing the ign. timing at the time). I know i no longer have the intake manifold leak. What can I do to get more low speed/ idle manners to this setup? Can I try advancing the cam? or do I need to turn up the idle speed and if so how far can I go? Perhaps I am overlooking something. I do have power brakes with a vacuum reservoir so I would like to be able to use them
How radical is that cam? personal experiences would really help.
Problem is, everywhere I look, i can only get information about vacuum for STOCK motors. With high performance, I should expect it to be lower, but I'm hoping I can improve the number from 5-7? I saw Rhoads lifters, but for $300 for a roller lifter set, I think I can spend that cash elsewhere.
Thanks in advance for any help,
BWill
351W
9.8:1 compression
BWill
