Working at a wrecking yard, I do at least two compession tests a day on engines. Your numbers look just fine to me. After running out of oil, everthing got really hot. The engine was likely really dry. The one cyl that was really high, probably had some oil left in it. Shooting more in it made the number shoot way up. I have cranked over engines dry and got 80 psi, shot a couple of squirts of oil down the cyl and it jumps to 300psi! Oil does not compress well, so it can really throw off the numbers! Even though the cars I work on are practically new, they can sit for 6 + months before I dismantle them. Like a car that sits your car is probably just thirsty for lubrication.
I would squirt a couple of shots of oil down each cyl with all the plugs out. Then I would crank the engine over for a minute. Then I would leave it over night and perform another compression test. Chances are you will get more uniform numbers. Good Luck!
