  • SN95 4.6L Mustang Tech
tools need for diy fmic install
  • Thread starter Thread starter stanggt00
  • Start date Start date Apr 18, 2007
stanggt00
371
baltimore md
Apr 18, 2007
  • Apr 18, 2007
any of you guys who have done diy fmic plz chime in i am about to get started on mine and i wanted to know are there any speical tools or things to look out for when doing this install going to be doing it in parts
intercool mounting first then next time i have off work i will reinstall the blower and do the pipping
i will also be cutting a larger whole on the passenger side near the cai wall
now as for the tools i know some one said a dremel and some kind of metal cutting saw
the98stang
2,408
Clovis, CA
Apr 18, 2007
  • Apr 18, 2007
I will be doing the same setup on my GT. Are you going to mount it into the bumper support? If so, you are going to need a metal cutter to get through that thick metal. I plan to mount mine from the radiator support, which doesn't require any cutting, except in the fender area.
stanggt00
371
baltimore md
Apr 18, 2007
  • Apr 18, 2007
i was planing to cut the support .
mounting it from radiator support will the intercooler get enuff air if mounted there ??
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Apr 18, 2007
  • Apr 18, 2007
you need a torch, cutoff wheel or plasma cutter to cut the support. then i used some snips to cut the hole in the inner fender area. other than that just regular hand tools
Rickey_Bobby
332
Sarasota, FL
Apr 18, 2007
  • Apr 18, 2007
sawzall, cutoff wheel/grinder, flux core welder, big hammer.
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
K
Door post and rust repair
  • Kleinjj27
  • Aug 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
Kleinjj27
K
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
Resolved Fixing a GT40P Valvetrain nightmare
  • foxbodyclark
  • May 21, 2025
Fox 5.0 Mustang Tech May 24, 2025
limp
