tools needed to remove window motor
Pretty easy. Remove screw to inside door handle, cover by side view mirror, then remove arm res bolts and swich screw, disconnect power window switch harnesses, pull clips from around door pannel, remove speaker, detach motor harness, 1/4" bolts hold the motor in. Whallah!!!
