sickstickGT03 said:I thought the governer stopped the car from going more than 129? I have gone faster, but I was in 4th gear so the governer doesn't apply.
billyfe390 said:This question is almost as bad as 4.10 vs 3.73.
The top speed in 5th on a gt with 3.27 gears is around 200mph.
That 200mph is theoritical only as your mustang does not have enough power to reach that speed.
Man, I've never seen a speedo get pegged that fast.
I only held it for about 10sec or so, but I figure I was going somewhere arond 160-170. The car was still pulling but that was plenty fast enough for me.StngStr said:The only 99+ that came with a speed limiter were the ones that came with 16 inch wheels stock. The tires on those aren't rated for higher speeds so I believe they are limited at approx. 120 mph. If it came with 17 inchers (2000 or 2001 and later) stock, there is no top speed governor, only a rev (RPM) limiter. Top speed with enough road should be somewhere around 150 on a stock GT. I've been 6000 rpm in 4th gear, which is 140 mph.
