Toploader Question
  • Thread starter Thread starter HammerG26
  • Start date Start date Mar 22, 2006
H
HammerG26
28
Canton, GA
Mar 22, 2006
  • Mar 22, 2006
I have a Toploader with a Hurst Competition shifter that I want to put in my 66 A Code Coupe (currently has a 3 speed in it). The numbers on the TopLoader are as follows:
RUG AV 1
023563
D2AR 7006-CA W2
I read the article in Mustang Monthly, and now know the tranny is for 70-71 Mustang, and it is a wide ratio, 28 spline TopLoader.
What is the advantage / disadvantage of the wide ratio?
Will the tranny work with my 289?
Thanks in advance,
Hammer
SoCalCruising
2,437
SoCal
Mar 22, 2006
  • Mar 22, 2006
Wide ratio is the prefered ratio by most people, IMHO. First gear is still higher than you might like - its 2.72, if I remember correctly, versus 3.35 for most T-5s, and 2.95for the motorsport T-5(z). IMO, the wide ratio allowed Ford to use it on big blocks where the torque load as much higher than on small blocks. That is, by reducing torque multiplication, the tranny could handle more flywheel torque.
I just swapped out a wide ratio toploader for a T-5, so I know what the toploader was like. It will work fine with your small block. You don't want the close ratio.
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Mar 22, 2006
  • Mar 22, 2006
The wide ratio toploader is a good tranny for any car with 3:50 or lower numerical rear end. Its first gear is 2.78, vs 2.32 for the close ratio.
The wide ratio toploader is the better street tranny. The close ratio is better suited for the drag strip (with a race engine) because it helps to keep a peaky engine in its torque band. I am not saying that close isn't also good on the street or that a wide ratio won't work at the track.
Only some 390 big blocks came with a wide ratio. All other big blocks were close ratio. www.4speedtoploaders.com
The toploader that you have will work great behind your 289.
mfp4073
387
Hells Ditch, FL
Mar 22, 2006
  • Mar 22, 2006
I have had both a wide ratio and close ratio in my car that is doing 290hp/285tq and perfer the wide ratio. I was actually at the point where I would run one for a while and then swap the other back in 6 months later, so I had a lot of back and forth experience. (socal meant that you dont want the close ratio).
The 4th gears are going to be the same 1-1 ratio, so the only thing that will change is that it will be more like starting off in second gear.
SoCalCruising
2,437
SoCal
Mar 22, 2006
  • Mar 22, 2006
Oops. mfp4073 (what kind of name is that?) is right. Now corrected.
C
Hurst Competition Plus shifter question
  • chuck gibson
  • Feb 19, 2023
3K
Classic Mustang Specific Tech Feb 27, 2023
dennis112
A
T5 conversion questions
  • Animal Lawyer
  • Jul 9, 2021
5K
Classic Mustang Specific Tech Aug 6, 2021
manicmechanic007
T
Shifter Rod Length 4 Speed Toploader
  • tjack96
  • May 14, 2018
2K
Classic Mustang Specific Tech May 15, 2018
horse sence
Oh No ! It Was A 64 1/2 ...
  • horse sence
  • Apr 25, 2016
2K
Classic Mustang Specific Tech Jul 23, 2019
02 281 GT
P
Toploader To T5 Installation Issues
  • Paul Greilich
  • Jun 14, 2016
4K
1965 - 1973 Classic Mustangs -General/Talk- Jun 18, 2016
65ShelbyClone
