  • SN95 4.6L Mustang Tech
Torgue Specs
  • Thread starter Thread starter Origommi
  • Start date Start date Aug 23, 2006
O
Origommi
180
  • Aug 23, 2006
Torque Specs
Anyone have the torque specs for putting back on the upper radiator hose to the them housing unit. I hear that if its not tight enough it leaks and if its to tight it cracks the manifold. Thanks guys.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Aug 23, 2006
  • Aug 23, 2006
I put mine on like the Swiss mechanic, Gooten Tight.
Yours has screw clamps? Mine had the compression clamps you need a set of channel locks to remove. I went back with the screw type and just tightend enough to compress the hose.
DTNODYA
831
  • Aug 23, 2006
If you are talking about the two long bolts that hold the thermostat housing to the intake manifold then be VERY careful!!! Clean the threads of the bolts with a brush and then put some never seez on the threads. Reason I say this is because I went to go change my thermostat one day and one of my bolts was a bitch to turn ... Finally, it broke right at the top of the threads. Bottom line, intake manifold had to come off, had to drill the bolt out (ez outs didn't work), then had to re-thread the hole! PITA!
So if you put never seez on the bolt threads, you shouldn't have issues with removing the bolts ever.
If these are the bolts you are talking about, for my 98 GT the recommended torque is 15-22 lb-ft.
O
Origommi
180
  • Aug 24, 2006
Mine is a 96GT with the long screws. I tightened them the other day and there is a small leak where the seam is (like I didnt tighten it down enough) I would had to torque it down to much and crack the therm housing. Is there a sealant anyone would suggest?
[Twitch]
168
Montreal
Aug 24, 2006
  • Aug 24, 2006
That's correct, thermostat housing bolts on a 4.6l V8 is 15-22lbs-ft.
[Twitch]
168
Montreal
Aug 24, 2006
  • Aug 24, 2006
RTV
Oil cooler delete 4v 4.6 1999 cobra mustang
  • sami12
  • Feb 24, 2026
SN95 4.6L Mustang Tech Feb 25, 2026
GOvert
G
L
Engine New guy heater hose question. 85 gt 4bbl.
  • linemech31
  • Jan 17, 2026
Fox 5.0 Mustang Tech Jan 20, 2026
General karthief
D
Drivetrain Will a broken s spring affect traction?
  • dqureshi06
  • Jan 12, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
Mustang5L5
Dipstick Issue?
  • Sonic
  • May 2, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 5, 2026
WhiteCobra95
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
