Torker II intake
  • Thread starter Thread starter 86bluecobra
  • Start date Start date May 24, 2006
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 24, 2006
  • May 24, 2006
Is anyone running a Torker II intake on a 351w carb'd? I found out that the vic jr requires a different msd dizzy then i have and i was wondering if anyone has run this intake or if it is even worth buying? I would like a single plane to go with my vic jr heads. i currently run a wiend stealth dual plane.
classic boost
709
canton, oh
May 25, 2006
  • May 25, 2006
the stealth is a better intake than the torker2. it's about a 20 year newer design and has bigger runners. keep the stealth.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 25, 2006
  • May 25, 2006
OK. I didn't really like the look of the torker II. Maybe a Super victor would be the way to go.
classic boost
709
canton, oh
May 25, 2006
  • May 25, 2006
what's the intended use of the car? a super victor will give up ALOT of torque.
5.0ina66
664
Ohio
May 25, 2006
  • May 25, 2006
Wieland excellerator? smallish single plane like the TokerII but seems to work much better.
1969mach1351
285
Sacramento, CA
May 25, 2006
  • May 25, 2006
I ran a Performer RPM and now a Torker II. Without changing the jets it ran 2 tenths slower. I went four sizes bigger on the secondaries and the Torker II ended up being two tenths faster than the RPM in the 1/4 mile.
69mach1DE
Delaware
Dec 16, 2006
  • Dec 16, 2006
I'm running a 351W, performer RPM intake & heads w/ 650 demon. I'm restoring my 1969 Mach 1 and want to use a shaker hood. It looks like the Torker II is a little shorter than the performer RPM intake and should fit with a shaker setup. Did you use a carb spacer. I'm rebuilding the rear with 4:11 track-loc. Did you lose anything on the low end when you switched to the torker ii?
allcarfan
The Answer Man
2,458
North Atlanta
Dec 18, 2006
  • Dec 18, 2006
torker II vs super victor????
thats like saying....do I need a 500cfm carb or an 850cfm carb
1969mach1351
285
Sacramento, CA
Dec 18, 2006
  • Dec 18, 2006
I don't remember about the heights of the two but they are really close. I have a 1" spacer with the Torker II and a 3 inch tall air cleaner with a drop base and it fits under the stock non-shaker hood. I didn't have the spacer with the RPM. My 60ft were the same or faster with the Torker so I didn't lose any bottom end.
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
Holley High-ram tuning settings
  • spencergt66
  • Apr 1, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jun 19, 2026
spencergt66
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
