• Community Forums
  • Regional Forums and Event Information
Torque converter help
  • Thread starter Thread starter lgbnaf7
  • Start date Start date Dec 5, 2006
L
lgbnaf7
61
Tacoma Wa
Dec 5, 2006
  • Dec 5, 2006
I am replacing the tranny in my 89 gt AOD. So i decided while the tranny is out that I should put in a shift kit and upgrade my torque converter. So here is my situation. I need some input on what brand of Torque converter and shift kit i should look into. My car is bone stock. If it wasn't for the TV cable disconnecting I wouldn't be doing tranny work. Any suggestions would be great Thanks
N
Npower
Camarillo, Ca
Dec 5, 2006
  • Dec 5, 2006
I used a b&m before it was ok, the precision industries torque converter I had was hands down awesome and custom made too, but a bit $$. http://www.converter.com/stallion.htm
ronburgundy
179
BC coast
Dec 5, 2006
  • Dec 5, 2006
go 200 miles north to tcs. i believe they build lentech's convertors. best convertors in the nw. (sw canada)
ronburgundy
179
BC coast
Dec 5, 2006
  • Dec 5, 2006
as for shifts kits, i usually use transgo. u have to be careful not to go too aggressive on a stock aod. (heavy rotating mass) unless you go to a solid input shaft and non lockup convertor. tcsproducts dot com
N
Npower
Camarillo, Ca
Dec 5, 2006
  • Dec 5, 2006
Yeah I second transgo...good stuff.
Johnnb
152
The Couve
Dec 6, 2006
  • Dec 6, 2006
I would honestly not go with a shift kit and just buy yourself a Lentech Valve body which will straighten out your shifting pattern, and get a good Lentech torque converter as well. The combination will make you very happy with the shifting and make your car seem a heck of a lot faster and the installation is cake.
T
time only
461
Miami,FL
Dec 6, 2006
  • Dec 6, 2006
Another vote for a Lentech Valve Body,it is well build and shift firm . Not having to playing around with springs and check balls is a plus with a bolt on Valve body. But if you could torn down a AOD tranny then you should have no problem with a shift kit too. For a stock car I would save a few buck and get a off the shelf B&M 2400 Holeshot or a Edge Converter. The excellent Lentech Converter is custom build to your Engine/Gearing combo and is kind of overkill for a stock Mustang. Plus you are looking a around $600 for that converter. I would use the saving on a tranny cooler ( A must with highter stall converter ) and a A-Servo set up.
T
time only
461
Miami,FL
Dec 8, 2006
  • Dec 8, 2006
time only said:
Another vote for a Lentech Valve Body,it is well build and shift firm . Not having to playing around with springs and check balls is a plus with a bolt on Valve body. But if you could torn down a AOD tranny then you should have no problem with a shift kit too. For a stock car I would save a few buck and get a off the shelf B&M 2400 Holeshot or a Edge Converter. The excellent Lentech Converter is custom build to your Engine/Gearing combo and is kind of overkill for a stock Mustang. Plus you are looking at around $600 for that converter. I would use the saving on a tranny cooler ( A must with highter stall converter ) and a A-Servo set up.
D
AOD with 4R70W Internals and a Shift Kit - 1 to 2 Shift Question
  • Davjake128
  • May 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 2, 2026
Davjake128
D
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
F
5R55S Torque Converter Grinding while seating
  • feloniusgru
  • Mar 2, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 2, 2026
ctandc
C
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
O
Help
  • OnisimusD
  • Oct 13, 2025
1965 - 1973 Classic Mustangs -General/Talk- Oct 14, 2025
OnisimusD
O
  • Community Forums
