Torque converter stall
The # rpm converter you get represents the rpm that the converter will hold back torque till.
For example, if you buy a 3000 stall it will hold back the torque till you reach 3000rpm. It helps you take off in or closer to your power band for maxuimum launches.
There are two ways to rate a torque converter, and that may be what's confusing you.
Foot brake torque.
Flash torque.
In either case, there are a few factors which will change the advertised stall speed of a converter no matter how it's rated.
weight of car
gearing
traction
engine acceleration are a few.
