torque spec on frpp1.6 rr
  • Thread starter Thread starter Beasly B
  • Start date Start date Jan 28, 2006
Beasly B
165
Virginia
Jan 28, 2006
  • Jan 28, 2006
I can't remember the torque specs on my ford motorsport roller rockers, does anyone know? It seems that on my passenger side they are ticking, just wondering if maybe one of them has loosened up, or maybe one is going bad.I'm going to pull the valve cover and hopefully see what's going on. If any suggestions please give them, thanks.
N
nidyanazo
Banned
Mar 30, 2005
149
805 dawg
Jan 28, 2006
  • Jan 28, 2006
Stock is 24ft/lb....
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jan 28, 2006
  • Jan 28, 2006
Setting them up is more complex than simply tightening them to a specific torque. The process is below -- I'd use 24 ft-lb on a cast iron head; I stopped mine at 20 ft-lbs. going into an aluminum head.
To install pedestal mount rockers:
1) For each pair (int/exh) be sure you rotate the engine so the lifters are on the base circle of the cam - this is very important. When you install the rockers, both valves must remain closed. Neither lifter can be on any part of the cam lobe - they MUST be on the base circle. Rotate the engine clockwise. Watch the pushrods for the pair you're installing. The exh will rise and fall; as it's about to 'close' (fall back down) the intake will rise. Keep rotating until the intake falls back down (closed) and both the intake and exhaust pushrods are the same height. You're now on the base circle of the cam at the beginning of the compression stroke for that cylinder.
2) Install the rocker and bolt it down to zero lash. Zero lash is reached just when you eliminate the gap between the pushrod and the rocker and the valve stem and the rocker. Tighten with one hand and 'rock' the rocker with the other hand. Just when you reach the point that you can't rock the rocker anymore you're at zero lash.
3) Now - put your torque wrench on it and tighten to 18-20 ft-lbs. while counting the number of turns it takes to reach that torque. It should occur between 1/4 turns and 1 turn. If it takes more than one turn, use a shim to raise the rocker. For each .030" shim you use, you'll reduce the number of turns to torque by about 1/4. If it takes less than 1/4 turn, or you have trouble reaching zero lash even with the bolt torqued all the way to 18-20, then you need longer pushrods.
4) If all goes well on the install, crank it up. If some make noise let the car warm up completely. Then (unfortunately) go back through the install procedure with the components warm. That will usually quiet them down.
Mine has 11 with no shims at all, 4 with one .030" shim, and one with 2 .030" shims. And I had to do the final install with it hot to get them quiet. That approach has them all hitting the required torque within 1/2 to 3/4 turns.
I have a Buddy Rawls custom cam with fairly steep ramp rates, 1.7 roller rockers (pedestal Cobra type), and stock lifters. It runs just about as quiet as it did stock.
Beasly B
165
Virginia
Jan 28, 2006
  • Jan 28, 2006
thanks for the info didn't know that I just tightened them all down I'll go back and do this, also where do you get the shims? thanks
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jan 28, 2006
  • Jan 28, 2006
My new roller rockers from FRPP came with a shim kit in the box; I know you can get them from FRPP.
H
1995 cobra engine noise help
  • Holt2010
  • Nov 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Nov 8, 2026
Holt2010
H
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
