Torque Specifications
veeeery happy with it. only problem i have is i spilled some coolant down an exhaust flange and crystalyzed an O2 sensor :(
i did not get a tune, car runs great as it is. no hesitation under WOT. i absolutly love it.
dont know the HP cuz i didnt dyno it yet...
if i'm recalling correctly, im pretty damn sure the head bolt specs were...
1. 28-31 ft-lb's
2. 90* extra turn
3. Loosen 1 full turn (first part stretches the bolt)
4. 28-31 ft-lb's again
5. 90* turn
6. another 90* turn
do each step to all bolts before going on.
intake manifold bolts are like 14-20 lb-ft's i think. and retorque after hot, but i didnt and im fine.
but yeah, if you're not perfect on the specs, dont worry. i only used a tq wrench on the head bolts and manifold bolts.
hardest part is getting the dip stick tube on, you WILL NEED an extra person at least to guide it in. its a difficult step and takes lots of patience. i didn thave to cut my old on before removing it. when u put it on, bolt it ot the head (or valve cover if you're 01+ heads) before putting the head on.
exhaust flange bolts were a pain just cuz i havent unbolted them in 8 years :doh:
dont mix up ur guides and tensionors, they're different.
i learned so much from this and researched it alot. if you have any more questions just PM/IM or post back.
oh, did u tap ur CT sensor yet? :shrug:
yeah, i'm rebulding the block so i need those specs. i'm also trying to find the intake manifold assembly. i saw it in ford racing but not anywhere else. any ideas?
2v torque specs
use SAE30 oil to lubricate
Main bolts stage1: 30ft-lb
stage2: +90degrees
RomeoBlock
side adjusting screws
stage1: 45in-lb
stage2: 90in-lb
side bolts
stage1: 90in-lb
stage2: 16ft-lb
Windsor Block
side bolts- dowel pins go in with flat side towards crank
stage 1: 22ft-lb
stage 2: +90degrees
2v Cylinder head
use SAE30 to lubricate
stage1: 30ft-lb
stage2: +90 degrees
stage3: loosen all bolts at least 1 full turn
stage4: 30ft-lb
stage5: +90degrees
stage6: +90degrees
and i hope i dont have to remind you to NEVER REUSE HEADBOLTS on a mod motor
thanks that helps a lot. i'm pretty much stuck without the intake assembly though. i'm going to do the pi head swap but i have a 96 2v block with just heads so i need everything else to replace it. i was able to find somethings but not much.
2v rest of motor specs
Rod Bolts lube with 32 weight
stage1: 10ft-lb
stage2: 30ft-lb
stage3: +90degrees
Rear Cover Bolts
100in-lb
Oil Pump to Block
100in-lb
Pickup Tube to pump
100in-lb
Pickup tube to standoff
20ft-lb
Oil Pan
20ft-lb
Timing Cover
20ft-lb
Flywheel Bolts
60ft-lb
Valve Cover
90in-lb
Crank Dampener
125ft-lb NEW BOLT, NEVER REUSE
Camshaft Bolt
M10 Bolt 30lb-ft +90degrees
M12 Bolt: 90ft-lb
Camshaft Bearing Cap Bolts
90in-lb
Timing Chain Tensioner
20ft-lb
Timing Chain Guide
95in-lb
Intake Manifold
18lb-ft
Spark Plugs
13ft-lb
