touchy steering
  • Thread starter Thread starter paul23122
  • Start date Start date Oct 9, 2011
P
paul23122
32
  • Oct 9, 2011
Have a strange problem with my 95 gt. The car tracks straight and no worn tires but on the feeway or some roads the car will want to dart left or right. While changing lanes of freeway instead of gradually moving over it just darts over very quickly (scares the hell out of you). Everything appears very tight. Any thought??? Bad caster angle or????
Thanks for the time.
-Paul
N
narcszm
9
Washington, USA
Oct 10, 2011
  • Oct 10, 2011
That's not your car; that's your front tires coming out of the ruts on the freeway. It is especially noticeable if you have wider front tires.
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Oct 10, 2011
  • Oct 10, 2011
Narcszm is correct. The term for it is "tramlining". A good alignment with the addition of a set of caster/camber plates can probably alleviate a lot of it by adding more caster.
Dino Dino Bambino
1,673
90
79
Cyprus
Oct 11, 2011
  • Oct 11, 2011
Caster isn't adjustable and doesn't need to be unless you've lowered the vehicle. If you have lowered it by more than 1-1/4" you'd be well advised to install adjustable CC plates, bumpsteer kit, and get a proper alignment. Check your steering rack bushings for wear and excessive deflection.
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Oct 11, 2011
  • Oct 11, 2011
Caster is adjustable with caster/camber plates, as I suggested.
ttopstang
306
Birmingham, AL
Oct 11, 2011
  • Oct 11, 2011
that sounds like over steer which is usually caused by worn ball joints. I had a car doing the same thing, alignment didn't really help, changed ball joints, that was it.
P
paul23122
32
  • Oct 11, 2011
That helps alot. I know the previous owner had put eibach springs on it but it doesnt appear to be much lower than stock. the other thing i forgot to mention is that when i hit about 60-70 mph the steering wheel tends to shimmy a little but only in that small mph range, any faster or slower it goes away. Does that help at all in diagnosing this darn thing!
Thanks again to all of you!!!
-Paul
dgollem
20+ Year Stangneter
May 5, 2004
212
33
49
Waldorf MD
Oct 11, 2011
  • Oct 11, 2011
The shimmy is probably cuased by out of balance tires. You can rotate front to rear and see if the shimmy changes or get everything rebalanced if it bothers you. Over time it may cause some cupping and increase wear but only if you drive a lot at the speed where the shimmy is.
ID89GT
1,659
18
49
Spokane Valley, WA
Oct 11, 2011
  • Oct 11, 2011
Could check the rag joint on the steering shaft too, but you said it drives straight normally so I wouldn't suspect it as much. My rag joint was completely shot and my car was all over on the freeway
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
