My 95 GT runs great once it starts. After sitting for the night it is very hard to start. It takes at least four or five times of cranking to get it to run. Seems that there is no gas in the injector rails when first started but will run fine for the remainder of the day once it's going.
Everything in the fuel system is new from the fuel pump to the injectors. Can not find any leaks in any line. The only thing I haven't found is maybe an external check valve to keep the fuel from draining back into the tank. I figured by changing the entire pump system inside the tank that would solve the problem. Nope, not yet.
Anyone have any suggestions?
