tps, harness from fivelogy problem
noslow1986
274
oswego Il
dont be like me and buy this harness i bought this harness so i didnt have to probe the tps wires. two of the wires didnt have a plastic piece over it and the green one did. so i hook it up anyways and the two wires with the metal clips touch, and screwed up my ground wire to the computer none of my sensors were grounded cause of the two wires touching and shorted something out in the computer. now i have a bad computer and need a new one had to make a ground just for now to get by. the instruction never said anything like this would happen. be careful with electic **** screw me up.
The two wires must have been the computer internal power and ground.
Setting the TPS is a useless proces, because everytime the engine is started, the computer zeros out the TPS setting. It will always reset the TPS value unless it is so far out of spec that it sets a code.
had a guy look at it and coulded get the tps to ground none of my sensor were grounded so he hook up this machine and ground it and all my sensor had a ground after hooking up a wire in the computer to the body . so he had to hook up a wire to temp ground the computer. it took two hours but it runs great it had to be the problem. now if ground and pos on the tps touch while driving wouldnt it short something out kind of like touching pos and neg battery cables together
