tps voltage problem
fox182
17
hey i have a 92 notch that started running a little weird one day i was checking around and my tps was showing 5 volts, i am definately checking the right wire and i also checked for shorts between wires, i replaced the tps, and still does it, this is driving me crazy i cant figure it out i dont kno if my computers shot or what, anyone else have this problem?
it sounds like your range is way off. i think its not supposed to be no more than 1.0 volt at idle, i dont know what the minimum is, i would have to check the specs for that and at wot.
Yeah it's definately way off it runs rich ever since it started I tried everything I could think of I just dot wanna by a new a9l and it not be the problem but it's the only think left I can think of
Which color wire are you checking. The green wire to Ground is what you want to find. The red wire I believe has 5v from the computer going through it. If you get 5v on both wires, then you are shorting somewhere between the red and green wires. Let us know. I can post pics if you need help
Geez guys.
Fox182, run the codes from the computer. You may have a burnt circuit on the ECM board. Fixable if that's the case.
Either run the codes, or go ahead and open the ECM up and look on the back of the board for the burnt trace up by the main 60 pin connector.
