Hi im in the process of installing a zex programmable tps switch(wot switch) but I need to know which wire from my tps sensor is the voltage output lead? thanks if anyone can help me out.
Green wire is signal out to computer. Black/white wire is signal ground from computer. Be sure to use both wires if you can. Also be careful not to connect the black/white wire to 12 volts or you will damage the computer and wiring.
Do it according to the directions and use the green wire.
The kit manufacturer must have decided to use chassis ground as a reference ground for the TPS. This isn't as accurate, but they may not need the same degree of precision as the computer does.
Did the install this last weekend..green wire as stated and good body ground with the control box black lead. If you have any questions or issues let me know...as I said I JUST finished the install sunday morning on my little girl.
sweet in gonna complete the install this weekend, im gonna mount the tps voltage box inside my car and im gonna hook up the green wire and im done, thanks!!!
