tps
  • Thread starter Thread starter cld783
  • Start date Start date Dec 9, 2004
C
cld783
  • Dec 9, 2004
simple question, do you have to adjust a brand new "throttle position sensor" when replaced? or do you only adjust your old ones or ones that may have been misadjusted? if so whats the best setting? thanks.
NYC LSC
626
Staten Island, NYC
Dec 9, 2004
  • Dec 9, 2004
Yes, you have to set it whenever it's been removed - new or old. Set it to 0.99v.
Good luck.
C
cld783
  • Dec 9, 2004
cool thanks man much appreciated, by the way nice wheelie id crap my pants if i pulled up next to you at a stop light and seen the front end come up like that.
C
cld783
  • Dec 9, 2004
damn near a wheelie anyways, lots of torque in that beast thats for damn sure.
The Shape
2,224
East ARKANSAS Delta
Dec 9, 2004
  • Dec 9, 2004
Good luck.
There is an on going discussion on this. I am not convinced it makes a difference.
CManT1914
3,172
Killeen, Texas
Dec 9, 2004
  • Dec 9, 2004
No I don't think you do. Our EEC baselines the TPS on startup. So no matter what you set it to, the computer resets it when you crank up the car. I never set mine last night when I swapped throttle bodys, and it didn't need it.
NYC LSC
626
Staten Island, NYC
Dec 9, 2004
  • Dec 9, 2004
So setting your TPS voltage to 0.99v is like an old wive's tale then?
How come I've heard that when ECM gets anything over 1.00v signal from the car, it's considered "cruising" voltage? I've had my TPS mis-adjusted (over 1v) and the idle would sit at 1500 for minutes at a time (and between shifts). Get it to .98 or .99 and the idle problem went away. Hell, the idle would raise like a bastard if I mistakenly pushed the sensor too far.
So what's the scoop on this? I'm curious. Because this link, and what I've heard for years, says different......? Talk to me, boys!
Edit: And thanks, cld783 . That picture is when it was a 15 second 'wonder'.
CManT1914
3,172
Killeen, Texas
Dec 9, 2004
  • Dec 9, 2004
I guess it depends on what computer you have in your car. I think the 87-93 you needed to, but the 94 and 95 you didn't. Or if you have the A9L computer you need to. But the stock 94-95 5.0 computers baselined it on startup.
rootus said:
Unless you have swapped your EEC to an A9L, there is no point in adjusting the TPS because it is baselined by the EEC on startup.
Dave
Take from this thread
NYC LSC
626
Staten Island, NYC
Dec 9, 2004
  • Dec 9, 2004
Ahh...I see. Thanks, CMan. Learn somethin' new everyday! Didn't know what year car he had, so I just went with what I've always known to do.
And FWIW my car's got an A9S swapped in.
C
cld783
#10
  • Dec 9, 2004
  • #10
ya ive actually heard that diff tps voltages have diff benefits but nothing much to really make a big deal about, mostly just set it somewhere near .98 .99 and make sure when you press the throttle its all smooth with no jumps in readings. i do have a 5.0 liter non HO efi 1989 motor out of a ford truck i believe in my 1986 crown victoria. so if that makes a difference in if i have to set it or not let me know.
HISSIN50
34
129
Dec 9, 2004
#11
  • Dec 9, 2004
  • #11
i have heard it all too. it should baseline itself, but then again, with all the idle-surge issues people have, i would remove all the 'extra' things the puter has to do (make it easier for the thing).
PNY PWR
522
Wichita, KS
Dec 10, 2004
#12
  • Dec 10, 2004
  • #12
I have an A9P and tried adjusting the TPS, never noticed any difference. Shop manual calls for .20 volts
HISSIN50
34
129
Dec 10, 2004
#13
  • Dec 10, 2004
  • #13
for real? im not one to mess with the setting, but i would if that was my static reading.
PNY PWR
522
Wichita, KS
Dec 11, 2004
#14
  • Dec 11, 2004
  • #14
Yeah, that's what it says, not a Ford shop manual but specs. shouldn't vary (though they probably do from one source to the next) I have mine set at .99v or so.
It says the minimum (closed throttle) should be set at .20v on the 5.0 and .34v on the 2.3. Maximum (WOT) is 4.84v for both engines.
88_GT_5_oh
Sportin' a turbo 5.0 in Canadistan
Jul 4, 2004
WPG/MB/CA
Dec 11, 2004
#15
  • Dec 11, 2004
  • #15
when i replaced mine i did not set anything, and it helped solve the bucking i was having with the old one in
HISSIN50
34
129
Dec 11, 2004
#16
  • Dec 11, 2004
  • #16
the thing about this is the parameters of the sensor. i would think that if one set it that low, it would be out of spec (most things on the EEC can adapt ~25%), and toss a code.
im not at all disbelieving you - i trust you and enjoy readin' your posts. i just am surprised at that spec. interesting.
281pony
2,681
Oly, WA
Dec 11, 2004
#17
  • Dec 11, 2004
  • #17
i have had alot of issues with my tps, so i finally got around to buying a new one. took my car being down for 3 months to get one at that
i tried to set mine to .99, highest i could get was .6x i believe. i kept getting the codes, so finally i just moved it to the opposite extremes and that was around .2x volts and the maximum of .6x volts.
at one point or another, each reading threw codes and then disappeared. i noticed some differences in them both. sometimes it would run normal, sometimes it was a noticable performance loss, less responsive, idle issues, lights dimming up to stops.
so i wouldnt necessarly agree you can just throw it on. maybe it had something to do with mine being shot though?
PNY PWR
522
Wichita, KS
Dec 11, 2004
#18
  • Dec 11, 2004
  • #18
Interesting post....there is supposed to be an adjustable and a non-adjustable TPS according to my manual. I would assume w/ the non-adjustable one could just throw it on.
HISSIN50
34
129
Dec 11, 2004
#19
  • Dec 11, 2004
  • #19
i dont follow the rumors that closely, but here goes: I think the 'non-adjustable' TPS's were for cars which are supposed to zero out at start up; thinking being that with such lash control, there was no need to fine tune it.
this did not stop people from hogging out holes and making them adjustable. LOL.
281pony
2,681
Oly, WA
Dec 11, 2004
#20
  • Dec 11, 2004
  • #20
the previous one had wide slots for adjustability. the new one which i havent used, has small holes and minimal adjustability.
i guess i must have one of each kind now?
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
TPs sensors different?
  • Creomod
  • Sep 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 11, 2026
DadLife0724
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
