  • SN95 4.6L Mustang Tech
Tracking...
  • Thread starter Thread starter streetstang03
  • Start date Start date Jun 16, 2005
streetstang03
unModerator
Dec 27, 2003
the dark side of the moon/home of the 1999, 2003,
Jun 16, 2005
  • Jun 16, 2005
whats the best fix for tracking? ever since i got my Nittos (265s), my car tracks like a mother ****er on rough roads. what suspension mod(s) help correct it UCAs??
Pertums
174
NY
Jun 16, 2005
  • Jun 16, 2005
with my 00 GT i had MAJOR tracking issues with my Pirelli tires.. then i put new firehawk wide ovals on and the tracking problem has gone completely away.
all i did was put the new rims/tires on from tirerack, and then drive to ford for an alignment. honestly i wish i did it sooner it used to make me so pissed off when it would veer from side to side on the highway.
streetstang03
unModerator
Dec 27, 2003
Jun 16, 2005
  • Jun 16, 2005
ttt
streetstang03
unModerator
Dec 27, 2003
Jun 17, 2005
  • Jun 17, 2005
streetstang03
unModerator
Dec 27, 2003
Jun 17, 2005
  • Jun 17, 2005
well, im going to wake my ass up early tomorrow and drop my car off to get an alignment. we'll see how that helps.
hognutz
1,940
albany, oregon
Jun 17, 2005
  • Jun 17, 2005
well I don't know if you can fix tramlining of a certain tire.
I am no expert but the only thing I can think of is different tire, differnet size tire.
I had avs sports last time an they were horrible. My bfg kdw-2's are so so. I think any truely high performance tire is going to follow the grooves a bit.
narrower tires and more sizewall tend to reduce it. tread design, lower profile, wider tires tend to increase it.
hotrodnut
672
North Florida
Jun 18, 2005
  • Jun 18, 2005
If you have caster/camber plates you can possibly get rid of some of it but probably not all because as others are saying, the tires are the problem. You could add more caster to the front end settings if you have the c/c plates and that will help it track better. Also reducing the toe-in to the minimum setting from the factory specs will help somewhat too.
streetstang03
unModerator
Dec 27, 2003
Jun 18, 2005
  • Jun 18, 2005
finally...some good replies
thanks guys!
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
G
Need tuning help with 4100 Carburetor
  • Gary’s 67
  • Aug 18, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 22, 2026
manicmechanic007
Tunerstudio help / services
  • Kabuki_notch
  • Apr 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum May 2, 2026
Mustang5L5
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
