  • 2007 - 2014 Shelby GT500 Tech
Traction Help......
  • Thread starter Thread starter pete_05_gt
  • Start date Start date Dec 25, 2015
pete_05_gt
48
Dec 25, 2015
  • Dec 25, 2015
Ok guys don't know if anyone seen I bought the 11' 500. It was already modded some with the 2.3 frpp s/c upgrade, cfm twin 67mm throttle body, jlt 123mm intake and a roush extreme exhaust. Plus it is an svt pp so 3.73 gears and so on. Problem is I can not hook even with 315/35/20 nitto invos out back. I wanna go to the track and get kicked off for no cage when it re-opens but I/m lost on how to make this thing hook. If you have any suggestions I am all ears thanks guys.
Svtpilot
944
59
59
Long Island, NY
Dec 26, 2015
  • Dec 26, 2015
Most of the guys in my area with 500s run drag radials on the rear. If you still have the factory rear lower control arms I would definitely replace them with aftermarket arms. The factory LCAs including the reinforced arms that came on your car pretty flimsy . The aftermarket arms are much beefier and have stiffer bushing so they will do a much better job of planting the rear. If you plan on going to the drag strip frequently I would think about buying a pair of 18x10 rims and set of slicks
pete_05_gt
48
Dec 26, 2015
  • Dec 26, 2015
Thank you
464
TX
Dec 28, 2015
  • Dec 28, 2015
Might want to upgrade the rear sway bar too. A stiffer rear bar will help both wheels to keep planted better. With a weak sway bar more load goes on the passenger rear tire less on the drivers. Result is less traction as both tires will spin sooner.
Svtpilot
944
59
59
Long Island, NY
Dec 29, 2015
  • Dec 29, 2015
^ I hate to disagree with some one with 2 cars as fast at the ones in your signature but in this case I think you may be mistaken. Correct me if I am wrong but simply put a sway bar works by tying both sides of the chassis to each other and the suspension.As the chassis rolls in relation to the suspension in a turn the sway bar resists the roll, the stronger the bar the more resistance. In straight line acceleration, especially with a car as powerful as a GT500 wouldn't a stiffer rear sway bar will try to lift the l/r tire as the engine causes the chassis to torque to the right?. I would however think about upgrading the panhard rod which will help keep the rear properly located under the chassis.
pete_05_gt
48
Dec 30, 2015
  • Dec 30, 2015
Nice info there pilot most appreciated. Steeda chromoly lca's odered then upper and panhard bar. I will keep you posted.
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,254
204
South Jersey
Dec 31, 2015
  • Dec 31, 2015
Needs different tires in my opinion... I have yet to see someone really get much done as far as straight line performance goes on Nitto Invo tires. Try a set of Mickey Thompson Drag Radials and you'll be surprised to see the difference.
Svtpilot
944
59
59
Long Island, NY
Dec 31, 2015
  • Dec 31, 2015
Cool, look forward to hearing about it. Don't forget the Drag Radial !
SpartaPerformance
2,517
61
89
Long Island NY
Jan 3, 2016
  • Jan 3, 2016
I've always wanted to try a torque arm on the S-197's, I've seen good things about Cortex. Does anybody have/know anybody with a torque arm set up?
464
TX
Mar 30, 2016
#10
  • Mar 30, 2016
  • #10
Try taking your rear sway bar off and then report back on the difference in traction. Been there, done that! A good stiff rear bar is absolutely necessary for improved traction.
Svtpilot
944
59
59
Long Island, NY
Mar 31, 2016
#11
  • Mar 31, 2016
  • #11
I never said anything about removing the sway bar to improve traction. But i still disagree that installing a stiffer bar will improve traction, unless you mean replacing the factory sway bar with one specifically made for drag racing such as the BMR Xtreme anti roll bar kit (http://bmrsuspension.com/?page=products&productid=189&superpro=0)
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
Help With Tires
  • pete_05_gt
  • May 9, 2016
2007 - 2014 Shelby GT500 Tech Nov 7, 2016
KLRVENUM
K
  • Locked
Expired 2015 Mustang Gt Premium Convertible (roush Supercharged And Inspired)
  • altjx
  • Sep 2, 2016
  • S550 Mustangs for Sale (2015+)
7K
S550 Mustangs for Sale (2015+) Sep 2, 2016
altjx
Thinking About Either Trading Or Selling My Mustang, What Do You Guys Think Its Worth?
  • usaf_branham
  • Apr 15, 2015
2K
1996 - 2004 SN95 Mustang -General/Talk- Apr 21, 2015
03_TrueBlue_GT
  • Locked
Expired For Sale: 2011 5.0 M6, Stealth Fighter
  • Sharad
  • Feb 5, 2015
  • S197 Mustangs For Sale (2005-14)
7K
S197 Mustangs For Sale (2005-14) Feb 5, 2015
Sharad
