Traction Help......
pete_05_gt
48
Ok guys don't know if anyone seen I bought the 11' 500. It was already modded some with the 2.3 frpp s/c upgrade, cfm twin 67mm throttle body, jlt 123mm intake and a roush extreme exhaust. Plus it is an svt pp so 3.73 gears and so on. Problem is I can not hook even with 315/35/20 nitto invos out back. I wanna go to the track and get kicked off for no cage when it re-opens but I/m lost on how to make this thing hook. If you have any suggestions I am all ears thanks guys.
Most of the guys in my area with 500s run drag radials on the rear. If you still have the factory rear lower control arms I would definitely replace them with aftermarket arms. The factory LCAs including the reinforced arms that came on your car pretty flimsy . The aftermarket arms are much beefier and have stiffer bushing so they will do a much better job of planting the rear. If you plan on going to the drag strip frequently I would think about buying a pair of 18x10 rims and set of slicks
Might want to upgrade the rear sway bar too. A stiffer rear bar will help both wheels to keep planted better. With a weak sway bar more load goes on the passenger rear tire less on the drivers. Result is less traction as both tires will spin sooner.
^ I hate to disagree with some one with 2 cars as fast at the ones in your signature but in this case I think you may be mistaken. Correct me if I am wrong but simply put a sway bar works by tying both sides of the chassis to each other and the suspension.As the chassis rolls in relation to the suspension in a turn the sway bar resists the roll, the stronger the bar the more resistance. In straight line acceleration, especially with a car as powerful as a GT500 wouldn't a stiffer rear sway bar will try to lift the l/r tire as the engine causes the chassis to torque to the right?. I would however think about upgrading the panhard rod which will help keep the rear properly located under the chassis.
Needs different tires in my opinion... I have yet to see someone really get much done as far as straight line performance goes on Nitto Invo tires. Try a set of Mickey Thompson Drag Radials and you'll be surprised to see the difference.
Try taking your rear sway bar off and then report back on the difference in traction. Been there, done that! A good stiff rear bar is absolutely necessary for improved traction.
