Traction Lock experts?
rd
3,316
63
109
Ocean Springs MS
I pulled the cover to my 82 7.5 in traction lock yesteday, looking for the source of my clunking and grabbing. it was original equipment in an 82 Mustang GL straight six automatic car. Should be the same as an 82 GT.
It's been awhile since I installed it.... I did not find any broken parts, but some wierd evidence of grinding on the pinion and a rounded groove in the rear face of the pinion and one tooth. Works fine after putting the cover back on and refilling with new oil. I used a non Ford additive for the first time.
Instead of an s-spring like all of my other Traction locks, it has 4 small coil springs, and apparently a 2 pc case. I don't have an exact reference manual, but is this a cone or a clutch type?
Anyone know how they come apart for service?
it has clutch plates i believe, i shattered the spider gears in my 82GT a while back, it really sucked..if i was you i'd be looking for an 8.8 and get it in there ASAP, the 7.5 isn't nearly as strong and the 82's only have slapper bars instead of the quad shock setup, which is much better and reduces axle hop big time..if you still want to rebuild it, on the side of the differential(pull the cover first, which reminds me, how did you fill the 7.5 back up with 90wt??) there is a little bolt that threads into the main pin that the spider gears ride on, remove that and slide the big pin TOWARDS you, not away from you in the case..or you'll never get it out..i;m tellin ya..anyway this has to happen before the axle shafts will come out, push in on the ends of the axles and pull out the C-clip with needle nose pliers, now the axles should slide out(remove andthing in the brake area that is in the way), remove the 2 main caps(bearing retainers) on the ends of the diff. and pull it out...from there i'm not really sure, there's many write ups around, good luck
~Mark~
Thanks. Your info helped.
This is the original, or at least the axle that came with the 82. It had a 2.73 gear so I put it in my 79 Capri to replace a 2.73 open that I robbed out of a Tbird 10 years ago.
It surprised me because I had the cover off and axles out when I installed it, and still did not realize that it was not a regular Ford/SVO style unit.
I have a 4.10 geared 7.5 in the 82, actually with the original housing from the 79, but with all Ford Racing/SVO stuff, gears and traction lok unit. So far, its held up to high 12's and high 7's in the eight, launched on the bottle.
Yes, I have an 8.8 in the garage, and had it in once already. I took it out because I wanted the 4.10 as its a better quarter mile gear. The 8.8 has 4.56 gears.
I had never seen this type of unit before.
These are pita to fill. I use a quart or gallon container of gear oil and one of those cheap pumps from the parts store that screws into the top of the bottle. I put a short hose into the fill opening and just pump away until its full. I usually add the posi additive before.
Its a bit easier if you jack the car and let the axle hang, but I am usually too lazy to do the extra jacking and moving stands.
