traction lock rebuild ?'s
  • Thread starter Thread starter Thenemesis
  • Start date Start date Oct 27, 2005
Thenemesis
321
chuckletown, sc
Oct 27, 2005
  • Oct 27, 2005
hey guys.. i have a traction lock from a 8.8 in a stang and then i also have a new raytech rebuild kit.. got this stuff in a package deal.. anywho how would u go about doing it? i'd like to do it myself.. the more stuff done on my car the better as i see it.. does it have to be done by a pro or something? thanks
Modular2v
3,222
23
99
oklahoma
Oct 27, 2005
  • Oct 27, 2005
get an eaton
Thenemesis
321
chuckletown, sc
Oct 27, 2005
  • Oct 27, 2005
lol i wish.. my extra chunk is in the auburn box that the guy bought lol other than that.. im broke.. workin with what i got here
rd
3,316
63
109
Ocean Springs MS
Oct 27, 2005
  • Oct 27, 2005
You should be able to change the clutches, etc, in the posi with the diff in the car.
Look around on here and other sites, you should be able to find detailed directions. Its not hard, but have plenty of time available. I don't recommend trying to add extra clutches, but I would try to shim the final clearance correctly, so the spider gears go back in easily. Make sure you have some friction modifier and gear oil to refill when done.
Thenemesis
321
chuckletown, sc
Oct 27, 2005
  • Oct 27, 2005
well its just a extra chunk that i have from a package deal i got.. came out of a 86 gt.. guy replaced the 86's with a 31 spline unit front auburn.. i just got his rebuild kit and traction lock for free so i thought it would be nice to have a fresh posi to put in the new rear end when ever it comes lol
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Oct 27, 2005
  • Oct 27, 2005
Check out http://www.angelfire.com/theforce/5ohcpa/cpa5ohtech001.htm for a good write-up on how to do it. The article on the website shows it being done with the Traction Lok out of the car, but it can be done while installed.
R
Randy Kemper
102
  • Oct 27, 2005
It's easier to do with the gear out of the car. Just remember where the shims go, it's not hard. Also you can leave out a metal clutch on each side and put one of you best fiber clutches from the old set in place of it. There should be a thread on this if you do a search. It's been a long time since I've done this so sorry I'm not more detailed, but you can do this in an hour or so.
BlownFiveLiter
18
108
Chicagoland
Oct 27, 2005
  • Oct 27, 2005
I'm one up on ya Randy. Got the link I posted from the 94-95 "how to" sticky thread.
squeeeg
1,905
Michigan
Oct 27, 2005
  • Oct 27, 2005
That website is the best resource that you are going to find. It walked me throuh it with no problem. Read it and print what you think you will need during the work. I had no problems at all.
R
Randy Kemper
102
#10
  • Oct 27, 2005
  • #10
Yes you do! I fell asleep on that one.
Thenemesis
321
chuckletown, sc
Oct 27, 2005
#11
  • Oct 27, 2005
  • #11
yea it seems to go into every detail.. exactly what a novice rear end guy needs lol i can take one out and put one it but i dont mess with gears lol i just ran outside and found my raytech rebuild kit for the rear with shims and bearings and stuff but i cant find my traction lock kit yet.. but i didnt dig to deep lol i have 3.73's for FRPP to put in so good thing he goes into detail about that to!
accidentprone86
189
Westminster Colorado
Oct 27, 2005
#12
  • Oct 27, 2005
  • #12
It is a peice of cake!! The hard part is geting the "s" spring back in.
I suggest rebuilding with the alternate stacking order if you plane on drag racing. Just make sure you shim it right.
Also, with the bolt the holds the retainer shaft in, Make sure you heat it up a ton. my'n snaped on me and i played hell geting it out!
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Engine on3 Conversion to draw through MAF?
  • sav22rem22
  • Oct 11, 2025
Fox 5.0 Mustang Tech Oct 11, 2025
sav22rem22
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
  • Sticky
Free Beta Access: Tool I Built to Hunt Fox Bodies Faster
  • MRaburn
  • Mar 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 7, 2026
FastDriver
