Traction options for 8"
  • Thread starter Thread starter afterglow
  • Start date Start date Feb 12, 2007
A
afterglow
89
  • Feb 12, 2007
I'm running a mild 351W on my '69 and am currently using an open 8" rear with 3.8 gears. I'd like to improve traction by adding some sort of LSD/locker. The car will be mainly for the street, minimal highway, occasional drag racing. Emphasis should be on streetability.....I don't want it locking when I don't want it to OTOH I don't want it spinning when it's not supposed to.....noise isn't much of a concern.
What would you guys recommend??
Shakin66
628
Waycross, Ga / Lake James, NC
Feb 12, 2007
  • Feb 12, 2007
My vote would be for a rebuilt traction loc. My friend that set up my 9" installed a Detriot locker and while it has taken care of my traction problem it hammers away like crazy when I turn.
Great68
691
Victoria BC
Feb 12, 2007
  • Feb 12, 2007
Well you do have a lot of options.
Detroit True-Trac (Torsion)
Trac-Lok (Limited Slip)
Auburn (Limited Slip)
Powertrax (Locker)
Detroit Locker
Limited slip and True-Trac are the most streetable. Limited slip will wear over time. Lockers won't wear and put the power to the ground the best, but are a bit tricky on the street sometimes. I don't know a whole lot about the True-Tracs so maybe someone else can chime in, but I think they are the best all-round.
iskwezm
4,159
20
79
Rowland Heights,California
Feb 12, 2007
  • Feb 12, 2007
we put a Detroit Locker in my buddies, cant even hear it
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Feb 13, 2007
  • Feb 13, 2007
Truetrac here. Quiet all the time.
The car always leaves 2 equal length black marks with heavy acceleration. The only other time I notice it is when I make a slow, hard turn, like when you leave a stop sign at an intersection and turn right. Then one wheel drags just a little (similiar to my old traction lock.)
A
afterglow
89
  • Feb 13, 2007
I've heard so many good things about the Truetrac but it seems like they don't make it for the 8". I checked Summit and it seems like my choices are Detroit Locker, EZLocker, Powertrax No-slip and Powertrax Lockright.
Out of these, I'm most interested in the No-slip....performance of a locker with the silence of an open differential.....what's not to like, right??
Do you think it'll work for my needs??
Vinyl66
398
  • Feb 13, 2007
You are not going to beat the strength of the Detroit Locker. That's what I have and can barely tell it's there in my automatic Mustang. I also have one in my '97 Jeep Wrangler and it reminds me it's there all the time. They are much more foregiving behind an automatic.
For a mostly street car I would get a Truetrac. They are strong, will not wear out like a Limited Slip, and have better street manners than a full locker.
They do have them at Summit:
http://store.summitracing.com/partdetail.asp?autofilter=1&part=DTL-912A580&N=700+115&autoview=sku
A
afterglow
89
  • Feb 13, 2007
Truetrac it is then!! Thanks for the tip.....
A
andrewmp6
15
  • Feb 13, 2007
id get a lsd or a air or cable type locker so it only locks when you tell it to
6T6coupe
219
#10
  • Feb 14, 2007
  • #10
I am a cheapskate so I found a used Trac Lok for $40 and rebuilt it for another $60. Then I added new 3.55 gears for $180 and installed it with a $80 kit. Total for all was less than $400.
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
J
What's it Worth? 93 coupe turbo
  • junkyardwarrior
  • Jan 16, 2022
  • What is it Worth?!?!?
2K
What is it Worth?!?!? Jan 28, 2022
Middleagecrisis
M
D
1994 GT issues
  • DLB1985
  • Jul 2, 2022
1994 - 1995 Specific Tech Jul 2, 2022
General karthief
E
For Sale 1989 LX Notch 410ci 85mm turbo 8 pt cage 9" rear end
  • EightyNineFive
  • Aug 22, 2021
4K
Fox Body Mustangs For Sale (1979-93) Jun 18, 2022
Freakinstang
F
