Would i benefit at all from aftermarket UCA's and LCA's while running BBK lowering springs and ET streets, or would it make no differnce because of the lowering springs
You'd definitely benefit over stock even with loweing springs. Whether your springs are single or progressive rate will also play a role in how much better they perform as well.
I was told that if you want to remove your quad shocks to put on wider tires you have to get uca's and lca's because the stock ones are too weak and the rear will move around on you if you remove them. So that is one benefit, you getting to put wider tires. And like the other guy said it still would be better over stock.
