- Dec 1, 2003
- 267
- 0
- 0
I have a Paxton on the way, and I need to think about traction. What do you all think I should get. O yea I have 3.90 gears too.
wht99gtconv said:I have a Paxton on the way, and I need to think about traction. What do you all think I should get. O yea I have 3.90 gears too.
How about Lakewood 90/10's struts?forpit2000gt said:look into UCA and LCA, suspension is as important as tire selection. Drag radials will help.
What kind of #'s are you expecting.2002BLGT said:i was gonna get that kit , but decided to go thru dallas mustang and got the vortech kit for 100 bucks more because it looks to be easier to upgrade down the road , but let me know what kind of numbers you get out of it , i would like to see how they stack up , i should be getting mine tuned next week .
I hope to get around 350-360. I already have:2002BLGT said:if i can get 350 rwhp and just as much or better torque , hopefully alot more torque ill be happy since i dont have a TB or plenum , and using the stock 02 mass air meter which is 85 mm but drawback is it has the air inlet temp sensor made in it , so i cant mount that between the blower and the motor , hopefully the tuner can adjust for that
2002BLGT said:Where are you located and where are you getting yours tuned , or are you going to run the chip they give you ? Im currently running vortechs but not for long .
