  • 1994 - 1995 Specific Tech
tranmission problem?
  • Thread starter Thread starter Mustangless
  • Start date Start date Aug 18, 2006
Mustangless
903
home
Aug 18, 2006
  • Aug 18, 2006
When you let off the throttle the car starts to act like it is trying to grab. It upshifts fine, its only when you let off of the throttle. Is this the tranmission, rearend or something else? also it acted like it went into neutral after slowing down alot. I gave it some gas and it reved up then went into gear.
I searched and it sounds like it might be the mlps?
edit: When it firsted started doing this I had changed
tv adder 1-2 = 50
1-2 time=0
tv adder 2-3 = 75
2-3 time=0
tv adder 3-4 = 75
Also, I went to the track that night. The first time I noticed it was messed up was on the 3rd pass the rpms shot up (went into neutral)
I have changed all the tv adders back to stock, and it still does it.
Bosko5.0
1,067
longwood, FL
Aug 23, 2006
  • Aug 23, 2006
this is probably the tranmission , is your transmission leaking, or a what speed does it shift into overdrive?
Mustangless
903
home
Aug 23, 2006
  • Aug 23, 2006
no leaking, and have not noticed anything about it shiffting to o/d
Mustangless
903
home
Aug 25, 2006
  • Aug 25, 2006
replaced the mlps and still have the problem. It does not seem to do it until it gets warm. When it shifts, sometimes it will go into neutral for a second. Then when it starts to slow down, it will almost start bucking. Best way I can describe it, is it feels like you hit the brakes then let off.
Mustangless
903
home
Aug 27, 2006
  • Aug 27, 2006
bump
This is getting worse. Today I had driven 200feet and it went into neutral. Does anyone know anything about replacing the mlps harness?
Bosko5.0
1,067
longwood, FL
Aug 27, 2006
  • Aug 27, 2006
you may need to take it to a tranny shop they should be able to diagnos it for free, my guess is the bands have warn out, change back to stock settings and see if that change it.
Mustangless
903
home
Sep 7, 2006
  • Sep 7, 2006
replace the mlps, and now the mlps harness but still have problems.
If you put it in 2 it will take off normal, but in d it will rev up.
It still jerks when slowing down too
It seems to only start the jerking after it warms up (not real sure about this)
but it does the neutral thing when its cold or warm
I have a massive cooler (30k)mounted below my radiator. I am also running mercon V
Does anyone know what a good rebuild kit brand is for a 4r70w?
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
