trannie cooler
  • Thread starter Thread starter cobraii74x
  • Start date Start date Jan 27, 2004
C
cobraii74x
253
Altoona, PA
Jan 27, 2004
  • Jan 27, 2004
Who here with automatic trannie runs an aftermarket trannie cooler? I've been getting mixed feedback and I want to ask you guys. Are they even needed ? My dad said they can just be bypassed into one another but his mechanical skills have been proven faulty. Thanks guys!
C
COBRAIIW
562
CT
Jan 27, 2004
  • Jan 27, 2004
I run one,I put it in series with the one in the radiator.Yeah,my feeling is if your going to add horses you should consider one.
Power Surge
1,516
Palm Coast, FL
Jan 27, 2004
  • Jan 27, 2004
An aftermarket trans cooler is NEVER a bad idea. Heat kills transmissions. The lower you can get your fluid temps, the longer your trans will live. It's that simple .
CanadianCobra
174
Edmonton, AB
Jan 27, 2004
  • Jan 27, 2004
I just put one in the Mustang. I haven't driven the car yet (well 10 minutes doesn't really count).
If you do any racing or put in a high-stall converter you should probably get one. Any sort of brake-stand will increase tranny temp a lot, so to be on the safe side a tranny cooler is a good idea.
I put my cooler in after the radiator just because thats what the instructions said.
My Blazer on the other hand is only using a tranny cooler. I'm guessing tha the tranny that I got replaced when I first bought it probably left shavings in the stock radiator part so they just hooked up a tranny cooler.
C
cobraii74x
253
Altoona, PA
Jan 28, 2004
  • Jan 28, 2004
anybody have any suggestions on brands/ or psi rating or any of that stuff ? its a C4.
windsoreight
99
Ocean City, MD
Jan 28, 2004
  • Jan 28, 2004
Running a tranny cooler is never a bad idea. Being a trans builder I can attest that heat kills transmissions. If you run any kind of stall I would run a large cooler and bypass the radiator. I usually use the newer style stacked cooler. They are harder to flush however but do a much better job than the fin style.
parthos
529
Bismarck ND
Jan 28, 2004
  • Jan 28, 2004
I run a b&m cooler on my II, the fluid comes from the trans to the radiator, then goes to the cooler in front of the radiator, and back to the trans. I was told that this is wrong, but I belive that if you cooling system is up to the task, why not cool the trans fluid to around what the engine is, then cool it some more at the external cooler. Works for me... Just don't use the zip tie mounts, make some out of aluminum to mount it from the radiator about one inch
Dano78
2,633
Vancouver, WA
Jan 30, 2004
  • Jan 30, 2004
Yeah, don't be like me... I got lazy and didn't install my B&M cooler back in after I swapped in the new eng/trans and with me running headers, it lasted about 2 or 3 months (weekend driving) before it started slipping and after that the fluid browned and smelled burnt and the fluid looks like liquid glitter. Now it takes like 3500 rpms to get it to back up....not good.
Case of Type F - $12.00
B&M Shift Kit- $35.00
Rebuilt C4 Trans - $350.00
TORCHING your new tranny because you were too lazy to install the cooler.....
PRICELESS!!
I
2000 GT Mustang - Transmission Cooler to Radiator o-rings
  • Iwarrior
  • Oct 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 4, 2025
Iwarrior
I
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
347 with Vortech V2 and Holley quick fuel, AFR Renegades a tremec tko 600 advice for newbie pls
  • Schargedfox
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 3, 2026
Schargedfox
G
Fox Tire Size for 16" Pony Wheels on 1984 LX Convertible
  • gw7
  • Jun 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Qtrhrse23
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
