Tranny bolts
get a nice long 36" extension with a swivel head. drop the crossmember and support the tranny with a jack. lower it a bit, not putting too much stress on everything else,and put some muscle on those bolts. no problem
Thanks! :nice:
yesterday i droped my trany by my self just put a jack under your oil pan with a block of wood on it. loosen the four bolts - bottom two are easy- use an extention with a swivel for top drivers side. and the same for the passengers but i found using a deeper socket worked a little better. for me it's alot easier than doing the bellhousing and tranny together.
Yea i agree. Its deff easier to drop the tranny first and work on the bellhousing by itself. You have plenty more room and it is much less awkard. Now i'm all confused. I dont remember if the swivel is still needed. I was actually reffering to when I dropped the AOD out. Its all one unit so the whole engine/tranny had to tilt back and thats when i used the extension. I guess it you want to do it all at once(bell and tranny) your gonna have to tilt it and use the extension.
I'm just happy the AOD stayed out and the tremec went in. It cant be much fun putting the auto back in. the 5 speed install was relativley painless and straight foward.
PS- never take out an AOD by yourself...;)
